[petsc-users] PETSC Test
Satish Balay
balay at mcs.anl.gov
Wed Jun 14 23:07:07 CDT 2017
Likely its hanging in gethostbyname() call - which is caued
by a mismatch in hostname.
What OS are you using? If linux - can you do the following?
sudo echo 127.0.0.1 `hostname` >> /etc/hosts
And retry?
Satish
On Thu, 15 Jun 2017, Mohamadreza Soltanian wrote:
> Hello All,
> I am trying to install and test PETSC. When I get to the test part, it
> seems everything get stuck in the following line. I was wondering if anyone
> can help. Thank you
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI
> process
