[petsc-users] PETSC Test
Wed Jun 14 23:21:05 CDT 2017
The command below should work on osx aswell..
Satish
On Thu, 15 Jun 2017, Mohamadreza Soltanian wrote:
> Hello Satish
> Thank you for your reply. I am using macOS Sierra 10.12.5.
> Thanks
> On Thu, Jun 15, 2017 at 12:07 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Likely its hanging in gethostbyname() call - which is caued
> > by a mismatch in hostname.
> > What OS are you using? If linux - can you do the following?
> > sudo echo 127.0.0.1 `hostname` >> /etc/hosts
> > And retry?
> > Satish
> > > Hello All,
> > > I am trying to install and test PETSC. When I get to the test part, it
> > > seems everything get stuck in the following line. I was wondering if
> > anyone
> > > can help. Thank you
> > > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> > MPI
> > > process
