[petsc-users] Rectangular matrices turned into square?
Barry Smith
bsmith at mcs.anl.gov
Wed Jul 12 15:04:36 CDT 2017
Are you talking about the below? If so, I suspect that the code is actually generating a square matrix, not a rectangular one. Hypre definitely cannot handle rectangular matrices.
Barry
PC Object: 2 MPI processes
type: hypre
HYPRE BoomerAMG preconditioning
HYPRE BoomerAMG: Cycle type V
HYPRE BoomerAMG: Maximum number of levels 25
HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
HYPRE BoomerAMG: Threshold for strong coupling 0.25
HYPRE BoomerAMG: Interpolation truncation factor 0.
HYPRE BoomerAMG: Interpolation: max elements per row 0
HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
HYPRE BoomerAMG: Maximum row sums 0.9
HYPRE BoomerAMG: Sweeps down 1
HYPRE BoomerAMG: Sweeps up 1
HYPRE BoomerAMG: Sweeps on coarse 1
HYPRE BoomerAMG: Relax down symmetric-SOR/Jacobi
HYPRE BoomerAMG: Relax up symmetric-SOR/Jacobi
HYPRE BoomerAMG: Relax on coarse Gaussian-elimination
HYPRE BoomerAMG: Relax weight (all) 1.
HYPRE BoomerAMG: Outer relax weight (all) 1.
HYPRE BoomerAMG: Using CF-relaxation
HYPRE BoomerAMG: Not using more complex smoothers.
HYPRE BoomerAMG: Measure type local
HYPRE BoomerAMG: Coarsen type Falgout
HYPRE BoomerAMG: Interpolation type classical
linear system matrix = precond matrix:
Mat Object: 2 MPI processes
type: mpiaij
rows=2112, cols=2112, bs=2
total: nonzeros=29056, allocated nonzeros=29056
total number of mallocs used during MatSetValues calls =0
using I-node (on process 0) routines: found 531 nodes, limit used is 5
> On Jul 12, 2017, at 2:55 PM, Adam Denchfield <adenchfi at hawk.iit.edu> wrote:
> Hi,
> Below I've attached the text file with my ksp_view. It's a time-dependent problem so I included ten time-steps. The information doesn't seem to be much different in the multiple time steps.
> ______________
> Regards,
> Adam Denchfield
> Peer Career Coach - Career Services
> Illinois Institute of Technology
> Bachelors of Science in Applied Physics (2018)
> Email: adenchfi at hawk.iit.edu
> My LinkedIn My ResearchGate Profile
> On Wed, Jul 12, 2017 at 2:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Adam,
> Please send the output from KSP view. We don't "change" the matrix but we might have some intermediate matrix of that other side, or it could be a bug in our output.
> Barry
> > On Jul 12, 2017, at 2:45 PM, Adam Denchfield <adenchfi at hawk.iit.edu> wrote:
> > Hi,
> > I'm using the FEniCS package, which uses DOLFIN/petsc4py (and thus petsc). If I'm understanding the libraries right, I'm assembling rectangular matrices and sending them to be solved in a KrylovSolver. However, with -ksp_view, I'm seeing 2112x2112 matrices, not 1062x2112 matrices. Does PETSc do conversions like this automatically during preconditioning or something? Trying to identify if this would be a behaviour on PETSc's part.
> > Regards,
> > Adam Denchfield
> <output_ksp.txt>
