[petsc-users] Rectangular matrices turned into square?
Adam Denchfield adenchfi at hawk.iit.edu
Wed Jul 12 14:55:13 CDT 2017
Below I've attached the text file with my ksp_view. It's a time-dependent
problem so I included ten time-steps. The information doesn't seem to be
much different in the multiple time steps.
______________
*Adam Denchfield*
*Peer Career Coach - Career Services*
Illinois Institute of Technology
*Bachelors of Science in Applied Physics (2018)*
Email: adenchfi at hawk.iit.edu
My LinkedIn <http://www.linkedin.com/in/adamrobertdenchfield> My
ResearchGate Profile <https://www.researchgate.net/profile/Adam_Denchfield>
On Wed, Jul 12, 2017 at 2:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Adam,
>     Please send the output from KSP view. We don't "change" the matrix but
> we might have some intermediate matrix of that other side, or it could be a
> bug in our output.
>    Barry
> > On Jul 12, 2017, at 2:45 PM, Adam Denchfield <adenchfi at hawk.iit.edu>
> wrote:
> > Hi,
> > I'm using the FEniCS package, which uses DOLFIN/petsc4py (and thus
> petsc). If I'm understanding the libraries right, I'm assembling
> rectangular matrices and sending them to be solved in a KrylovSolver.
> However, with -ksp_view, I'm seeing 2112x2112 matrices, not 1062x2112
> matrices. Does PETSc do conversions like this automatically during
> preconditioning or something? Trying to identify if this would be a
> behaviour on PETSc's part.
> > Regards,
> > Adam Denchfield
> > My LinkedIn My ResearchGate Profile
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170712/9ea4d899/attachment-0001.html>
KSP Object: 2 MPI processes
  type: preonly
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
  left preconditioning
  using NONE norm type for convergence test
PC Object: 2 MPI processes
  type: lu
    LU: out-of-place factorization
    tolerance for zero pivot 2.22045e-14
    matrix ordering: natural
    factor fill ratio given 0., needed 0.
      Factored matrix follows:
        Mat Object:         2 MPI processes
          type: mpiaij
          rows=1056, cols=1056
          package used to perform factorization: mumps
          total: nonzeros=51008, allocated nonzeros=51008
          total number of mallocs used during MatSetValues calls =0
            MUMPS run parameters:
              SYM (matrix type):                   0
              PAR (host participation):            1
              ICNTL(1) (output for error):         6
              ICNTL(2) (output of diagnostic msg): 0
              ICNTL(3) (output for global info):   0
              ICNTL(4) (level of printing):        0
              ICNTL(5) (input mat struct):         0
              ICNTL(6) (matrix prescaling):        7
              ICNTL(7) (sequentia matrix ordering):7
              ICNTL(8) (scalling strategy):        77
              ICNTL(10) (max num of refinements):  0
              ICNTL(11) (error analysis):          0
              ICNTL(12) (efficiency control):                         1
              ICNTL(13) (efficiency control):                         0
              ICNTL(14) (percentage of estimated workspace increase): 20
              ICNTL(18) (input mat struct):                           3
              ICNTL(19) (Shur complement info):                       0
              ICNTL(20) (rhs sparse pattern):                         0
              ICNTL(21) (solution struct):                            1
              ICNTL(22) (in-core/out-of-core facility):               0
              ICNTL(23) (max size of memory can be allocated locally):0
              ICNTL(24) (detection of null pivot rows):               0
              ICNTL(25) (computation of a null space basis):          0
              ICNTL(26) (Schur options for rhs or solution):          0
              ICNTL(27) (experimental parameter):                     -8
              ICNTL(28) (use parallel or sequential ordering):        1
              ICNTL(29) (parallel ordering):                          0
              ICNTL(30) (user-specified set of entries in inv(A)):    0
              ICNTL(31) (factors is discarded in the solve phase):    0
              ICNTL(33) (compute determinant):                        0
              CNTL(1) (relative pivoting threshold):      0.01
              CNTL(2) (stopping criterion of refinement): 1.49012e-08
              CNTL(3) (absolute pivoting threshold):      0.
              CNTL(4) (value of static pivoting):         -1.
              CNTL(5) (fixation for null pivots):         0.
              RINFO(1) (local estimated flops for the elimination after analysis):
                [0] 932479.
                [1] 869485.
              RINFO(2) (local estimated flops for the assembly after factorization):
                [0]  34069.
                [1]  32553.
              RINFO(3) (local estimated flops for the elimination after factorization):
                [0]  932479.
                [1]  869485.
              INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
              [0] 1
              [1] 1
              INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                [0] 1
                [1] 1
              INFO(23) (num of pivots eliminated on this processor after factorization):
                [0] 544
                [1] 512
              RINFOG(1) (global estimated flops for the elimination after analysis): 1.80196e+06
              RINFOG(2) (global estimated flops for the assembly after factorization): 66622.
              RINFOG(3) (global estimated flops for the elimination after factorization): 1.80196e+06
              (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
              INFOG(3) (estimated real workspace for factors on all processors after analysis): 51008
              INFOG(4) (estimated integer workspace for factors on all processors after analysis): 12612
              INFOG(5) (estimated maximum front size in the complete tree): 73
              INFOG(6) (number of nodes in the complete tree): 277
              INFOG(7) (ordering option effectively use after analysis): 2
              INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
              INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 51008
              INFOG(10) (total integer space store the matrix factors after factorization): 12612
              INFOG(11) (order of largest frontal matrix after factorization): 73
              INFOG(12) (number of off-diagonal pivots): 0
              INFOG(13) (number of delayed pivots after factorization): 0
              INFOG(14) (number of memory compress after factorization): 0
              INFOG(15) (number of steps of iterative refinement after solution): 0
              INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 1
              INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 2
              INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 1
              INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 2
              INFOG(20) (estimated number of entries in the factors): 51008
              INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 1
              INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 2
              INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
              INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
              INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
              INFOG(28) (after factorization: number of null pivots encountered): 0
              INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 51008
              INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
              INFOG(32) (after analysis: type of analysis done): 1
              INFOG(33) (value used for ICNTL(8)): 7
              INFOG(34) (exponent of the determinant if determinant is requested): 0
  linear system matrix = precond matrix:
    type: mpiaij
    total: nonzeros=7264, allocated nonzeros=7264
      not using I-node (on process 0) routines
  type: bcgs
  maximum iterations=10000000
  tolerances:  relative=3e-15, absolute=3e-15, divergence=10000.
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
  type: hypre
    HYPRE BoomerAMG preconditioning
    HYPRE BoomerAMG: Cycle type V
    HYPRE BoomerAMG: Maximum number of levels 25
    HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
    HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
    HYPRE BoomerAMG: Threshold for strong coupling 0.25
    HYPRE BoomerAMG: Interpolation truncation factor 0.
    HYPRE BoomerAMG: Interpolation: max elements per row 0
    HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
    HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
    HYPRE BoomerAMG: Maximum row sums 0.9
    HYPRE BoomerAMG: Sweeps down         1
    HYPRE BoomerAMG: Sweeps up           1
    HYPRE BoomerAMG: Sweeps on coarse    1
    HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
    HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
    HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
    HYPRE BoomerAMG: Relax weight  (all)      1.
    HYPRE BoomerAMG: Outer relax weight (all) 1.
    HYPRE BoomerAMG: Using CF-relaxation
    HYPRE BoomerAMG: Not using more complex smoothers.
    HYPRE BoomerAMG: Measure type        local
    HYPRE BoomerAMG: Coarsen type        Falgout
    HYPRE BoomerAMG: Interpolation type  classical
    type: mpiaij
    rows=2112, cols=2112, bs=2
    total: nonzeros=29056, allocated nonzeros=29056
      using I-node (on process 0) routines: found 531 nodes, limit used is 5
  type: preonly
  type: lu
          type: mpiaij
          rows=4160, cols=4160
          total: nonzeros=308450, allocated nonzeros=308450
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
              RINFOG(1) (global estimated flops for the elimination after analysis): 2.09297e+07
              RINFOG(2) (global estimated flops for the assembly after factorization): 483549.
              RINFOG(3) (global estimated flops for the elimination after factorization): 2.09297e+07
              INFOG(3) (estimated real workspace for factors on all processors after analysis): 308450
              INFOG(4) (estimated integer workspace for factors on all processors after analysis): 49482
              INFOG(5) (estimated maximum front size in the complete tree): 167
              INFOG(6) (number of nodes in the complete tree): 881
              INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 308450
              INFOG(10) (total integer space store the matrix factors after factorization): 49482
              INFOG(11) (order of largest frontal matrix after factorization): 167
              INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 7
              INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 13
              INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 7
              INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 13
              INFOG(20) (estimated number of entries in the factors): 308450
              INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 6
              INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 12
              INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 308450
              INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 2, 4
    type: mpiaij
    total: nonzeros=47360, allocated nonzeros=47360
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      0.50000
TC =      0.50000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      1.00000
TC =      1.00000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      1.50000
TC =      1.50000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      2.00000
TC =      2.00000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      2.50000
TC =      2.50000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      3.00000
TC =      3.00000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      3.50000
TC =      3.50000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      4.00000
TC =      4.00000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      4.50000
TC =      4.50000
  type: bcgs
  type: hypre
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 8.38453e+06
                [1] 1.25452e+07
                [0]  182266.
                [1]  301283.
                [0]  8.38453e+06
                [1]  1.25452e+07
              [0] 6
              [1] 7
                [0] 6
                [1] 7
                [0] 1736
                [1] 2424
    type: mpiaij
  type: preonly
  type: lu
          type: mpiaij
                [0] 932479.
                [1] 869485.
                [0]  34069.
                [1]  32553.
                [0]  932479.
                [1]  869485.
              [0] 1
              [1] 1
                [0] 1
                [1] 1
                [0] 544
                [1] 512
    type: mpiaij
TC =      5.00000
TC =      5.00000
