[petsc-users] issue with ghost points
Gideon Simpson
gideon.simpson at gmail.com
Mon Feb 27 21:18:17 CST 2017
Not sure if this is a bug or not, but, for the following code:
#include <petscvec.h>
#include <petscdm.h>
#include <petscdmda.h>
typedef struct{
PetscScalar u;
PetscScalar v;
}b_node;
int main(int argc, char **args)
char dataname[PETSC_MAX_PATH_LEN] = "testvec.bin";
PetscInt N = 8;
DM dm;
Vec b;
PetscScalar mass, eng;
PetscViewer viewer;
DMDALocalInfo info;
b_node * b_array;
Vec b_local;
PetscInt local_index, local_width, i;
PetscScalar u, v;
PetscInitialize(&argc,&args,NULL,NULL);
PetscOptionsGetInt(NULL,NULL,"-N",&N,NULL);
DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_GHOSTED, N, 2 , 1 , NULL, &dm);
DMCreateGlobalVector(dm ,&b);
/* Load vector from disk */
PetscViewerBinaryOpen(PETSC_COMM_WORLD,dataname, FILE_MODE_READ, &viewer);
VecLoad(b, viewer);
PetscViewerDestroy(&viewer);
/* Inspect with viewer */
VecView(b, PETSC_VIEWER_STDOUT_WORLD);
DMGetLocalVector(dm,&b_local);
DMGlobalToLocalBegin(dm,b,INSERT_VALUES,b_local);
DMGlobalToLocalEnd(dm,b,INSERT_VALUES,b_local);
DMDAVecGetArray(dm, b_local, &b_array);
DMDAGetCorners (dm, &local_index, NULL, NULL,&local_width, NULL, NULL);
/* Zero out the ghost points */
if(info.xs == 0){
b_array[-1].u =0.0;
b_array[-1].v =0.0;
if(info.xs + info.xm == info.mx){
b_array[info.mx].u =0.0;
b_array[info.mx].v =0.0;
/* Manually inspect */
for(i=local_index;i<local_index+local_width;i++){
u = b_array[i].u;
v = b_array[i].v;
PetscPrintf(PETSC_COMM_WORLD," %i: u = %g, v = %g\n", i, u, v);
DMDAVecRestoreArray (dm,b_local,&b_array);
DMRestoreLocalVector(dm,&b_local);
VecDestroy(&b);
DMDestroy(&dm) ;
PetscFinalize();
return 0;
I am getting the output
Vec Object: 1 MPI processes
type: seq
Vec Object:Vec_0x84000000_0 1 MPI processes
type: mpi
Process [0]
1.
0.
0.707107
0.707107
6.12323e-17
1.
-0.707107
0.707107
-1.
1.22465e-16
-0.707107
-0.707107
-1.83697e-16
-1.
0.707107
-0.707107
0: u = 0., v = 0.
1: u = 0.707107, v = 0.707107
2: u = 6.12323e-17, v = 1.
3: u = -0.707107, v = 0.707107
4: u = -1., v = 1.22465e-16
5: u = -0.707107, v = -0.707107
6: u = -1.83697e-16, v = -1.
7: u = 0.707107, v = -0.707107
The input vector is an alternating sequence of cos( pi / 4 * j), sin(pi/4 * j), for j = 0,1,2…7. What I want to point out is that the first element of this vector, as it is read in, is 1. But when we do the manually looping, it spits out u = 0 at index i = 0. If i turn off the piece of code that zeros out the ghost points, the problem disappears. The reason I am concerned is that this kind of looping through the local vector with ghost points shows up in a piece of my code, and I am now concerned about the output. Do I have a bug here?
-gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170227/08dfd81e/attachment.html>
