[petsc-users] issue with ghost points
Barry Smith
bsmith at mcs.anl.gov
Mon Feb 27 21:28:25 CST 2017
You are using the info struct without ever having set values into it You are, at a minimum, missing a call to DMDAGetLocalInfo(). Valgrind would immediately have found the use of uninitialized values.
Note that DMDAGetCorners() provides some of the information that DMDAGetLocalInfo() provides but in a slightly different format.
Barry
> On Feb 27, 2017, at 9:18 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
> Not sure if this is a bug or not, but, for the following code:
> #include <petscvec.h>
> #include <petscdm.h>
> #include <petscdmda.h>
> typedef struct{
> PetscScalar u;
> PetscScalar v;
> }b_node;
> int main(int argc, char **args)
> char dataname[PETSC_MAX_PATH_LEN] = "testvec.bin";
> PetscInt N = 8;
> DM dm;
> Vec b;
> PetscScalar mass, eng;
> PetscViewer viewer;
> DMDALocalInfo info;
> b_node * b_array;
> Vec b_local;
> PetscInt local_index, local_width, i;
> PetscScalar u, v;
> PetscInitialize(&argc,&args,NULL,NULL);
> PetscOptionsGetInt(NULL,NULL,"-N",&N,NULL);
> DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_GHOSTED, N, 2 , 1 , NULL, &dm);
> DMCreateGlobalVector(dm ,&b);
> /* Load vector from disk */
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,dataname, FILE_MODE_READ, &viewer);
> VecLoad(b, viewer);
> PetscViewerDestroy(&viewer);
> /* Inspect with viewer */
> VecView(b, PETSC_VIEWER_STDOUT_WORLD);
> DMGetLocalVector(dm,&b_local);
> DMGlobalToLocalBegin(dm,b,INSERT_VALUES,b_local);
> DMGlobalToLocalEnd(dm,b,INSERT_VALUES,b_local);
> DMDAVecGetArray(dm, b_local, &b_array);
> DMDAGetCorners (dm, &local_index, NULL, NULL,&local_width, NULL, NULL);
> /* Zero out the ghost points */
> if(info.xs == 0){
> b_array[-1].u =0.0;
> b_array[-1].v =0.0;
> if(info.xs + info.xm == info.mx){
> b_array[info.mx].u =0.0;
> b_array[info.mx].v =0.0;
> /* Manually inspect */
> for(i=local_index;i<local_index+local_width;i++){
> u = b_array[i].u;
> v = b_array[i].v;
> PetscPrintf(PETSC_COMM_WORLD," %i: u = %g, v = %g\n", i, u, v);
> DMDAVecRestoreArray (dm,b_local,&b_array);
> DMRestoreLocalVector(dm,&b_local);
> VecDestroy(&b);
> DMDestroy(&dm) ;
> PetscFinalize();
> return 0;
> I am getting the output
> Vec Object: 1 MPI processes
> type: seq
> Vec Object:Vec_0x84000000_0 1 MPI processes
> type: mpi
> Process [0]
> 1.
> 0.
> 0.707107
> 0.707107
> 6.12323e-17
> 1.
> -0.707107
> 0.707107
> -1.
> 1.22465e-16
> -0.707107
> -0.707107
> -1.83697e-16
> -1.
> 0.707107
> -0.707107
> 0: u = 0., v = 0.
> 1: u = 0.707107, v = 0.707107
> 2: u = 6.12323e-17, v = 1.
> 3: u = -0.707107, v = 0.707107
> 4: u = -1., v = 1.22465e-16
> 5: u = -0.707107, v = -0.707107
> 6: u = -1.83697e-16, v = -1.
> 7: u = 0.707107, v = -0.707107
> The input vector is an alternating sequence of cos( pi / 4 * j), sin(pi/4 * j), for j = 0,1,2…7. What I want to point out is that the first element of this vector, as it is read in, is 1. But when we do the manually looping, it spits out u = 0 at index i = 0. If i turn off the piece of code that zeros out the ghost points, the problem disappears. The reason I am concerned is that this kind of looping through the local vector with ghost points shows up in a piece of my code, and I am now concerned about the output. Do I have a bug here?
> -gideon
