[petsc-users] Number of unknowns/proc for scaling tests
Mon Feb 27 11:08:56 CST 2017
On Mon, Feb 27, 2017 at 10:29 AM, Casalegno Francesco <
francesco.casalegno at epfl.ch> wrote:
> Hello,
> I am pretty new to PETSc and I would like to get some advice on choosing
> the right ratio of unknowns/proc.
> I have implemented a finite element solver for 3D problems with
> potentially up to 5B vertices, using CG as iterative solver. To run weak
> scaling tests I have to keep constant the ratio unknowns/proc, but if that
> if this ratio is too small I will not see any scaling as the communication
> overhead would dominate. Similarly, for strong scaling tests I expect to
> observe nearly-linear scaling only up to a certain number of procs, after
> which communications will dominate.
> My question is: what is a reasonable minimum number of unknowns per proc
> to get good scaling efficiency? I know that for <50k unknowns a direct
> solver would be preferable, but I do not know if this number is also a
> reasonable guess for the ratio unknown/proc.
 We have normally recommended > 10K, but of course this depends on the
speed of the processor/memory vs. the network, and the
arithmetic intensity of your algorithm. Consider using the "performance
spectrum" plot. Here is an example:
  https://hpgmg.org/2016/06/21/isc16-list/
You run a variety of problem sizes, and you can see where strong scaling
starts to tail off on the left edge.
     Matt
> Thanks in advance for your help!
> Francesco
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170227/bc9811fc/attachment.html>
