[petsc-users] configure cannot find a c preprocessor
Santiago Andres Triana repepo at gmail.com
Wed Dec 20 16:46:17 CST 2017
Dear petsc-users,
I'm trying to install petsc in a cluster using SGI's MPT. The mpicc
compiler is in the search path. The configure command is:
./configure --with-scalar-type=complex --with-mumps=1 --download-mumps
--download-parmetis --download-metis --download-scalapack
However, this leads to an error (configure.log attached):
             Configuring PETSc to compile on your system
TESTING: checkCPreprocessor from
config.setCompilers(config/BuildSystem/config/setCompilers.py:599)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Cannot find a C preprocessor
The configure.log says something about cpp32, here's the excerpt:
Possible ERROR while running preprocessor: exit code 256
stderr:
gcc: error: cpp32: No such file or directory
Any ideas of what is going wrong? any help or comments are highly
appreciated. Thanks in advance!
Andres
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171220/b0807565/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171220/b0807565/attachment-0001.obj>
