[petsc-users] Advices to decrease bicgstab iterations
    Jed Brown
    jed at jedbrown.org
    Wed Dec 13 01:39:36 CST 2017
When asking solvers advice, please always explain the problem you are
solving and the discretization that you use.
Edoardo alinovi <edoardo.alinovi at gmail.com> writes:
> Dear petsc users,
> I am doing some calculations to test my code in parallel using petsc. With
> respect the serial code, which uses an in house bicstab+diagonal ILU
> preconditioner, I note that petsc's bicgstab+ASM with standard options need
> a larger number of iterations to converge (order 3 to 5). In base on your
> expirience, do you have any method to improve the preconditioning?
> Thak you  ery much,
> Edoardo
