[petsc-users] Advices to decrease bicgstab iterations
Edoardo alinovi edoardo.alinovi at gmail.com
Wed Dec 13 01:46:39 CST 2017
Ps: I am solving Navier-Stokes equation (pressure-correction equation in
particular).  The matrix is sparse and in mpiaij fotmat.
Il 13 Dic 2017 8:39 AM, "Jed Brown" <jed at jedbrown.org> ha scritto:
> When asking solvers advice, please always explain the problem you are
> solving and the discretization that you use.
> Edoardo alinovi <edoardo.alinovi at gmail.com> writes:
> > Dear petsc users,
> > I am doing some calculations to test my code in parallel using petsc.
> With
> > respect the serial code, which uses an in house bicstab+diagonal ILU
> > preconditioner, I note that petsc's bicgstab+ASM with standard options
> need
> > a larger number of iterations to converge (order 3 to 5). In base on your
> > expirience, do you have any method to improve the preconditioning?
> > Thak you  ery much,
> > Edoardo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171213/0f404567/attachment-0001.html>
