[petsc-users] Advices to decrease bicgstab iterations
Edoardo alinovi edoardo.alinovi at gmail.com
Wed Dec 13 01:28:00 CST 2017
Dear petsc users,
I am doing some calculations to test my code in parallel using petsc. With
respect the serial code, which uses an in house bicstab+diagonal ILU
preconditioner, I note that petsc's bicgstab+ASM with standard options need
a larger number of iterations to converge (order 3 to 5). In base on your
expirience, do you have any method to improve the preconditioning?
Thak you  ery much,
Edoardo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171213/b1f92ff9/attachment.html>
