[petsc-users] Matrix-free vs finite differenced Jacobian approximation
Matthew Knepley
knepley at gmail.com
Tue Dec 12 11:39:19 CST 2017
On Tue, Dec 12, 2017 at 12:26 PM, Alexander Lindsay <
alexlindsay239 at gmail.com> wrote:
> Ok, I'm going to go back on my original statement...the physics being run
> here is a sub-set of a much larger set of physics; for the current set the
> hand-coded Jacobian actually appears to be quite good.
> With hand-coded Jacobian, -pc_type lu, the convergence is perfect:
> 0 Nonlinear |R| = 2.259203e-02
> 0 Linear |R| = 2.259203e-02
> 1 Linear |R| = 1.129089e-10
> 1 Nonlinear |R| = 6.295583e-11
> So yea I guess at this point I'm just curious about the different behavior
> between `-snes_fd` and `-snes_fd -snes_mf_operator`. Does the hand-coded
> result change your opinion Matt that the rules for FormFunction/Jacobian
> might be being violated?
> I understand that a finite difference approximation of the true Jacobian *is
> an approximation. *However, in the absence of possible complications like
> Matt suggested where an on-the-fly calculation might stand a better chance
> of capturing the behavior, I would expect both `-snes_mf_operator -snes_fd`
> and `-snes_fd` to suffer from the same approximations, right?
There are too many things that do not make sense:
1) How could LU be working with -snes_mf_operator?
What operator are you using here. The hand-coded Jacobian?
2) How can LU take more than one iterate?
1 Linear |R| = 2.258733e-02
2 Linear |R| = 3.103342e-06
3 Linear |R| = 6.779865e-12
That seems to say that we are not solving a linear system for some reason.
3) Why would -snes_fd be different from a hand-coded Jacobian?
Did you try -snes_type test?
Matt
On Tue, Dec 12, 2017 at 9:43 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Dec 12, 2017 at 11:30 AM, Alexander Lindsay <
>>> I'm not using any hand-coded Jacobians.
>> This looks to me like the rules for FormFunction/Jacobian() are being
>> broken. If the residual function
>> depends on some third variable, and it changes between calls independent
>> of the solution U, then
>> the stored Jacobian could look wrong, but one done every time on the fly
>> might converge.
>> Matt
>>> Case 1 options: -snes_fd -pc_type lu
>>> 1 Linear |R| = 7.821248e-11
>>> 1 Nonlinear |R| = 2.258733e-02
>>> 0 Linear |R| = 2.258733e-02
>>> 1 Linear |R| = 5.277296e-11
>>> 2 Nonlinear |R| = 2.258733e-02
>>> 1 Linear |R| = 5.993971e-11
>>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 2
>>> Case 2 options: -snes_fd -snes_mf_operator -pc_type lu
>>> 1 Nonlinear |R| = 7.497740e-06
>>> 0 Linear |R| = 7.497740e-06
>>> 1 Linear |R| = 8.265413e-12
>>> 2 Nonlinear |R| = 7.993729e-12
>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
>>> On Tue, Dec 12, 2017 at 9:12 AM, zakaryah . <zakaryah at gmail.com> wrote:
>>>> When you say "Jacobians are bad" and "debugging the Jacobians", do you
>>>> mean that the hand-coded Jacobian is wrong? In that case, why would you be
>>>> surprised that the finite difference Jacobians, which are "correct" to
>>>> approximation error, perform better? Otherwise, what does "Jacobians are
>>>> bad" mean - ill-conditioned? Singular? Not symmetric? Not positive
>>>> definite?
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171212/b493b729/attachment.html>
