[petsc-users] Matrix-free vs finite differenced Jacobian approximation
    Alexander Lindsay
    alexlindsay239 at gmail.com
    Tue Dec 12 13:48:37 CST 2017
On Tue, Dec 12, 2017 at 10:39 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Dec 12, 2017 at 12:26 PM, Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
>> Ok, I'm going to go back on my original statement...the physics being run
>> here is a sub-set of a much larger set of physics; for the current set the
>> hand-coded Jacobian actually appears to be quite good.
>> With hand-coded Jacobian, -pc_type lu, the convergence is perfect:
>>  0 Nonlinear |R| = 2.259203e-02
>>       0 Linear |R| = 2.259203e-02
>>       1 Linear |R| = 1.129089e-10
>>  1 Nonlinear |R| = 6.295583e-11
>> So yea I guess at this point I'm just curious about the different
>> behavior between `-snes_fd` and `-snes_fd -snes_mf_operator`. Does the
>> hand-coded result change your opinion Matt that the rules for
>> FormFunction/Jacobian might be being violated?
>> I understand that a finite difference approximation of the true Jacobian *is
>> an approximation. *However, in the absence of possible complications
>> like Matt suggested where an on-the-fly calculation might stand a better
>> chance of capturing the behavior, I would expect both `-snes_mf_operator
>> -snes_fd` and `-snes_fd` to suffer from the same approximations, right?
> There are too many things that do not make sense:
> 1) How could LU be working with -snes_mf_operator?
>      What operator are you using here. The hand-coded Jacobian?
Why wouldn't LU work with -snes_mf_operator? My understanding is that LU is
configured to operate interchangeably with iterative preconditioners.
Jacobian:
(lldb) call MatView(snes->jacobian, 0)
Mat Object: 1 MPI processes
  type: mffd
  Matrix-free approximation:
    err=1.49012e-08 (relative error in function evaluation)
    The compute h routine has not yet been set
Preconditioner is computed with with SNESComputeJacobianDefault
> 2) How can LU take more than one iterate?
>       1 Linear |R| = 2.258733e-02
>       2 Linear |R| = 3.103342e-06
>       3 Linear |R| = 6.779865e-12
> That seems to say that we are not solving a linear system for some reason.
I'm curious about the same thing :-) Perhaps because B^-1 is not a perfect
inverse of the action of J on x in the matrix-free case? If I actually run
with matrix-free J and *hand-coded* B, I do get one linear iteration:
SMP jacobian PJFNK, -pc_type lu:
      1 Linear |R| = 2.857149e-11
 1 Nonlinear |R| = 1.404604e-11
 Solve Converged!
>  3) Why would -snes_fd be different from a hand-coded Jacobian?
>   Did you try -snes_type test?
The matrix ratio norm of the difference is on the order of 1e-6, which
isn't perfect but here the hand-coded performs better than the
finite-differenced Jacobian.
Alex
>   Matt
> On Tue, Dec 12, 2017 at 9:43 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Dec 12, 2017 at 11:30 AM, Alexander Lindsay <
>>>> I'm not using any hand-coded Jacobians.
>>> This looks to me like the rules for FormFunction/Jacobian() are being
>>> broken. If the residual function
>>> depends on some third variable, and it changes between calls independent
>>> of the solution U, then
>>> the stored Jacobian could look wrong, but one done every time on the fly
>>> might converge.
>>>    Matt
>>>> Case 1 options: -snes_fd -pc_type lu
>>>>       1 Linear |R| = 7.821248e-11
>>>>  1 Nonlinear |R| = 2.258733e-02
>>>>       0 Linear |R| = 2.258733e-02
>>>>       1 Linear |R| = 5.277296e-11
>>>>  2 Nonlinear |R| = 2.258733e-02
>>>>       1 Linear |R| = 5.993971e-11
>>>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations
>>>> 2
>>>> Case 2 options: -snes_fd -snes_mf_operator -pc_type lu
>>>>  1 Nonlinear |R| = 7.497740e-06
>>>>       0 Linear |R| = 7.497740e-06
>>>>       1 Linear |R| = 8.265413e-12
>>>>  2 Nonlinear |R| = 7.993729e-12
>>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
>>>> On Tue, Dec 12, 2017 at 9:12 AM, zakaryah . <zakaryah at gmail.com> wrote:
>>>>> When you say "Jacobians are bad" and "debugging the Jacobians", do you
>>>>> mean that the hand-coded Jacobian is wrong?  In that case, why would you be
>>>>> surprised that the finite difference Jacobians, which are "correct" to
>>>>> approximation error, perform better?  Otherwise, what does "Jacobians are
>>>>> bad" mean - ill-conditioned?  Singular?  Not symmetric?  Not positive
>>>>> definite?
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171212/c5a10136/attachment-0001.html>
