[petsc-users] Matrix-free vs finite differenced Jacobian approximation
Alexander Lindsay
alexlindsay239 at gmail.com
Tue Dec 12 11:26:46 CST 2017
Ok, I'm going to go back on my original statement...the physics being run
here is a sub-set of a much larger set of physics; for the current set the
hand-coded Jacobian actually appears to be quite good.
With hand-coded Jacobian, -pc_type lu, the convergence is perfect:
0 Nonlinear |R| = 2.259203e-02
0 Linear |R| = 2.259203e-02
1 Linear |R| = 1.129089e-10
1 Nonlinear |R| = 6.295583e-11
So yea I guess at this point I'm just curious about the different behavior
between `-snes_fd` and `-snes_fd -snes_mf_operator`. Does the hand-coded
result change your opinion Matt that the rules for FormFunction/Jacobian
might be being violated?
I understand that a finite difference approximation of the true Jacobian *is
an approximation. *However, in the absence of possible complications like
Matt suggested where an on-the-fly calculation might stand a better chance
of capturing the behavior, I would expect both `-snes_mf_operator -snes_fd`
and `-snes_fd` to suffer from the same approximations, right?
On Tue, Dec 12, 2017 at 9:43 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Dec 12, 2017 at 11:30 AM, Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
>> I'm not using any hand-coded Jacobians.
> This looks to me like the rules for FormFunction/Jacobian() are being
> broken. If the residual function
> depends on some third variable, and it changes between calls independent
> of the solution U, then
> the stored Jacobian could look wrong, but one done every time on the fly
> might converge.
> Matt
>> Case 1 options: -snes_fd -pc_type lu
>> 1 Linear |R| = 7.821248e-11
>> 1 Nonlinear |R| = 2.258733e-02
>> 0 Linear |R| = 2.258733e-02
>> 1 Linear |R| = 5.277296e-11
>> 2 Nonlinear |R| = 2.258733e-02
>> 1 Linear |R| = 5.993971e-11
>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 2
>> Case 2 options: -snes_fd -snes_mf_operator -pc_type lu
>> 1 Linear |R| = 2.258733e-02
>> 2 Linear |R| = 3.103342e-06
>> 3 Linear |R| = 6.779865e-12
>> 1 Nonlinear |R| = 7.497740e-06
>> 0 Linear |R| = 7.497740e-06
>> 1 Linear |R| = 8.265413e-12
>> 2 Nonlinear |R| = 7.993729e-12
>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
>> On Tue, Dec 12, 2017 at 9:12 AM, zakaryah . <zakaryah at gmail.com> wrote:
>>> When you say "Jacobians are bad" and "debugging the Jacobians", do you
>>> mean that the hand-coded Jacobian is wrong? In that case, why would you be
>>> surprised that the finite difference Jacobians, which are "correct" to
>>> approximation error, perform better? Otherwise, what does "Jacobians are
>>> bad" mean - ill-conditioned? Singular? Not symmetric? Not positive
>>> definite?
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171212/91fe2b86/attachment.html>
