[petsc-users] Matrix-free vs finite differenced Jacobian approximation
Alexander Lindsay
alexlindsay239 at gmail.com
Tue Dec 12 10:30:44 CST 2017
I'm not using any hand-coded Jacobians.
Case 1 options: -snes_fd -pc_type lu
0 Nonlinear |R| = 2.259203e-02
0 Linear |R| = 2.259203e-02
1 Linear |R| = 7.821248e-11
1 Nonlinear |R| = 2.258733e-02
0 Linear |R| = 2.258733e-02
1 Linear |R| = 5.277296e-11
2 Nonlinear |R| = 2.258733e-02
1 Linear |R| = 5.993971e-11
Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 2
Case 2 options: -snes_fd -snes_mf_operator -pc_type lu
1 Linear |R| = 2.258733e-02
2 Linear |R| = 3.103342e-06
3 Linear |R| = 6.779865e-12
1 Nonlinear |R| = 7.497740e-06
0 Linear |R| = 7.497740e-06
1 Linear |R| = 8.265413e-12
2 Nonlinear |R| = 7.993729e-12
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
On Tue, Dec 12, 2017 at 9:12 AM, zakaryah . <zakaryah at gmail.com> wrote:
> When you say "Jacobians are bad" and "debugging the Jacobians", do you
> mean that the hand-coded Jacobian is wrong? In that case, why would you be
> surprised that the finite difference Jacobians, which are "correct" to
> approximation error, perform better? Otherwise, what does "Jacobians are
> bad" mean - ill-conditioned? Singular? Not symmetric? Not positive
> definite?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171212/7fe0694d/attachment.html>
