[petsc-users] GAMG
Matthew Knepley
knepley at gmail.com
Fri Oct 28 08:30:45 CDT 2016
On Fri, Oct 28, 2016 at 8:24 AM, Jeremy Theler <jeremy at seamplex.com> wrote:
> Hi Mark.
> The matrix is solved well with lu/preonly.
> If I do not call PCSetCoordinates() the error goes away but convergence
> is slow.
Is it possible that your coordinates lie on a 2D surface? All this does is
make the 6 basis vectors
for translations and rotations. You can just make these yourself and call
MatSetNearNullSpace()
and see what you get.
Matt
> I call PCSetCoordinates() this way (1 processor):
> PetscMalloc1(dimensions * mesh->n_nodes, &coords);
> for (j = 0; j < mesh->n_nodes; j++) {
> for (d = 0; d < dimensions; d++) {
> coords[j*dimensions + d] = mesh->node[j].x[d];
> PCSetCoordinates(pc, dimensions, dimensions * mesh->n_nodes,
> coords);
> PetscFree(coords);
> Thanks
> jeremy
> On Fri, 2016-10-28 at 09:16 -0400, Mark Adams wrote:
> > I think there is something wrong with your matrix. Use any solver and
> > verify that you like the solution first.
> > On Fri, Oct 28, 2016 at 9:13 AM, Jeremy Theler <jeremy at seamplex.com>
> > wrote:
> > Hi! I want to use PCGAMG as a preconditioner for a 3D linear
> > elasticity
> > problem (displacement-based FEM formulation) over an
> > unstructured grid.
> > I am not using DMPlex, I just build the stiffness matrix
> > myself and pass
> > it to PETSc.
> > I set MatSetBlockSize() to 3 and pass the node coordinates
> > through
> > PCSetCoordinates(). But using gamg and gmres I get:
> > PETSc error 77-0 'Eigen estimator failed: DIVERGED_NANORINF at
> > iteration
> > 0'
> > in /home/gtheler/libs/petsc-3.7.4/src/ksp/ksp/impls/cheby/
> cheby.c
> > KSPSolve_Chebyshev:440
> > Any suggestion? Another PC/KSP combination to try?
> > Thanks
> > jeremy
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161028/f97cc259/attachment.html>
