[petsc-users] GAMG
Jeremy Theler jeremy at seamplex.com
Fri Oct 28 08:24:32 CDT 2016
Hi Mark.
The matrix is solved well with lu/preonly.
If I do not call PCSetCoordinates() the error goes away but convergence
is slow.
I call PCSetCoordinates() this way (1 processor):
    PetscMalloc1(dimensions * mesh->n_nodes, &coords);
    for (j = 0; j < mesh->n_nodes; j++) {
      for (d = 0; d < dimensions; d++) {
        coords[j*dimensions + d] = mesh->node[j].x[d];
    PCSetCoordinates(pc, dimensions, dimensions * mesh->n_nodes,
coords);
    PetscFree(coords);
Thanks
jeremy
On Fri, 2016-10-28 at 09:16 -0400, Mark Adams wrote:
> I think there is something wrong with your matrix. Use any solver and
> verify that you like the solution first.
> On Fri, Oct 28, 2016 at 9:13 AM, Jeremy Theler <jeremy at seamplex.com>
> wrote:
>         Hi! I want to use PCGAMG as a preconditioner for a 3D linear
>         elasticity
>         problem (displacement-based FEM formulation) over an
>         unstructured grid.
>         I am not using DMPlex, I just build the stiffness matrix
>         myself and pass
>         it to PETSc.
>         I set MatSetBlockSize() to 3 and pass the node coordinates
>         through
>         PCSetCoordinates(). But using gamg and gmres I get:
>         PETSc error 77-0 'Eigen estimator failed: DIVERGED_NANORINF at
>         iteration
>         0'
>         in /home/gtheler/libs/petsc-3.7.4/src/ksp/ksp/impls/cheby/cheby.c
>         KSPSolve_Chebyshev:440
>         Any suggestion? Another PC/KSP combination to try?
>         Thanks
>         jeremy
