[petsc-users] Column #j is wrong in parallel from message "Inserting a new nonzero (i, j) into matrix"
Dave May
dave.mayhem23 at gmail.com
Fri Oct 21 13:15:04 CDT 2016
On 21 October 2016 at 18:55, Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> I am on a new issue with a message:
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Argument out of range
> [1]PETSC ERROR: New nonzero at (374328,1227) caused a malloc
> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
> off this check
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
> [1]PETSC ERROR: /pmi/ericc/projetm4/depots_prepush/BIB/bin/BIBMEF.opt on
> a arch-linux2-c-debug named lorien by eric Fri Oct 21 13:46:51 2016
> [1]PETSC ERROR: Configure options --prefix=/opt/petsc-3.7.2_debug_matmatmult_mpi
> --with-mpi-compilers=1 --with-make-np=12 --with-shared-libraries=1
> --with-mpi-dir=/opt/openmpi-1.10.2 --with-debugging=yes
> --with-mkl_pardiso=1 --with-mkl_pardiso-dir=/opt/intel/composerxe/mkl
> --download-ml=yes --download-mumps=yes --download-superlu=yes
> --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes
> --download-metis=yes --download-suitesparse=yes --download-hypre=yes
> --with-scalapack=1 --with-scalapack-include=/opt/intel/composerxe/mkl/include
> --with-scalapack-lib="-L/opt/intel/composerxe/mkl/lib/intel64
> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
> --with-blas-lapack-dir=/opt/intel/composerxe/mkl/lib/intel64
> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 616 in
> /groshd/ericc/petsc-3.7.2-debug/src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: #2 MatAssemblyEnd_MPIAIJ() line 724 in
> [1]PETSC ERROR: #3 MatAssemblyEnd() line 5194 in
> /groshd/ericc/petsc-3.7.2-debug/src/mat/interface/matrix.c
> I am starting to debug, but I just want to be sure that the indices 374328
> and 1227 are both global indices...
They are.
> re-reading the thread makes me think yes... but I am not 100% sure...
> Thanks,
> Eric
> On 26/03/15 09:52 PM, Barry Smith wrote:
>> Eric,
>> I have now updated all the standard MPI matrix types AIJ, BAIJ, SBAIJ
>> to print the correct global indices in the error messages when a new
>> nonzero location is generated thus making debugging this issue easier. In
>> the branches barry/fix-inserting-new-nonzero-column-location, next and
>> the next release.
>> Thanks for pushing on this. The previous code was too "developer
>> centric" and not enough "user centric" enough.
>> Barry
>> On Mar 25, 2015, at 1:03 PM, Eric Chamberland <
>>> Hi,
>>> while looking for where in the world do I insert the (135,9) entry in my
>>> matrix, I have discovered that the column # shown is wrong in parallel!
>>> I am using PETsc 3.5.3.
>>> The full error message is:
>>> [0]PETSC ERROR: MatSetValues_MPIAIJ() line 564 in
>>> /home/mefpp_ericc/petsc-3.5.3/src/mat/impls/aij/mpi/mpiaij.c Inserting
>>> a new nonzero (135, 9) into matrix
>>> This line code is a call to a #defined macro:
>>> MatSetValues_SeqAIJ_B_Private(row,col,value,addv);
>>> where the "col" parameter is not equal to "in[j]"!!!
>>> in gdb, printing "in[j]" gave me:
>>> print in[j]
>>> $6 = 537
>>> while "col" is:
>>> print col
>>> $7 = 9
>>> So, I expected to have a message telling me that (135,537) and not
>>> (135,9) is a new entry matrix!!!
>>> Would it be a big work to fix this so that the col # displayed is
>>> correct?
>>> Thanks!
>>> Eric
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161021/78bb4120/attachment.html>
