[petsc-users] Column #j is wrong in parallel from message "Inserting a new nonzero (i, j) into matrix"
    Eric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Fri Oct 21 12:55:56 CDT 2016
I am on a new issue with a message:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Argument out of range
[1]PETSC ERROR: New nonzero at (374328,1227) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
off this check
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
[1]PETSC ERROR: /pmi/ericc/projetm4/depots_prepush/BIB/bin/BIBMEF.opt on
a arch-linux2-c-debug named lorien by eric Fri Oct 21 13:46:51 2016
[1]PETSC ERROR: Configure options
--prefix=/opt/petsc-3.7.2_debug_matmatmult_mpi --with-mpi-compilers=1
--with-make-np=12 --with-shared-libraries=1
--with-mpi-dir=/opt/openmpi-1.10.2 --with-debugging=yes
--with-mkl_pardiso=1 --with-mkl_pardiso-dir=/opt/intel/composerxe/mkl
--download-ml=yes --download-mumps=yes --download-superlu=yes
--download-superlu_dist=yes --download-parmetis=yes
--download-ptscotch=yes --download-metis=yes --download-suitesparse=yes
--download-hypre=yes --with-scalapack=1
--with-scalapack-include=/opt/intel/composerxe/mkl/include
--with-scalapack-lib="-L/opt/intel/composerxe/mkl/lib/intel64
-lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
--with-blas-lapack-dir=/opt/intel/composerxe/mkl/lib/intel64
[1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 616 in
/groshd/ericc/petsc-3.7.2-debug/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: #2 MatAssemblyEnd_MPIAIJ() line 724 in
[1]PETSC ERROR: #3 MatAssemblyEnd() line 5194 in
/groshd/ericc/petsc-3.7.2-debug/src/mat/interface/matrix.c
I am starting to debug, but I just want to be sure that the indices
374328 and 1227 are both global indices...
re-reading the thread makes me think yes... but I am not 100% sure...
Eric
On 26/03/15 09:52 PM, Barry Smith wrote:
>   Eric,
>   I have now updated all the standard MPI matrix types AIJ, BAIJ, SBAIJ to print the correct global indices in the error messages when a new nonzero location is generated thus making debugging this issue easier. In the branches barry/fix-inserting-new-nonzero-column-location, next and the next release.
>    Thanks for pushing on this. The previous code was too "developer centric" and not enough "user centric" enough.
>    Barry
>> On Mar 25, 2015, at 1:03 PM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
>> Hi,
>> while looking for where in the world do I insert the (135,9) entry in my matrix, I have discovered that the column # shown is wrong in parallel!
>> I am using PETsc 3.5.3.
>> The full error message is:
>> [0]PETSC ERROR: MatSetValues_MPIAIJ() line 564 in /home/mefpp_ericc/petsc-3.5.3/src/mat/impls/aij/mpi/mpiaij.c Inserting a new nonzero (135, 9) into matrix
>> This line code is a call to a #defined macro:
>> MatSetValues_SeqAIJ_B_Private(row,col,value,addv);
>> where the "col" parameter is not equal to "in[j]"!!!
>> in gdb, printing "in[j]" gave me:
>> print in[j]
>> $6 = 537
>> while "col" is:
>> print col
>> $7 = 9
>> So, I expected to have a message telling me that (135,537) and not (135,9) is a new entry matrix!!!
>> Would it be a big work to fix this so that the col # displayed is correct?
>> Thanks!
>> Eric
