[petsc-users] DG within DMPlex
Matthew Knepley
knepley at gmail.com
Tue Oct 4 10:26:12 CDT 2016
On Tue, Oct 4, 2016 at 10:23 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Mon, Oct 3, 2016 at 9:51 PM, Praveen C <cpraveen at gmail.com> wrote:
> >> DG for elliptic operators still makes lot of sense if you have
> >> problems with discontinuous coefficients
> > This is thrown around a lot, but without justification. Why is it better
> > for discontinuous coefficients? The
> > solution is smoother than the coefficient (elliptic regularity). Are DG
> > bases more efficient than high order
> > cG for this problem? I have never seen anything convincing.
> CG is non-monotone and the artifacts are often pretty serious for
> high-contrast coefficients, especially when you're interested in
> gradients (flow in porous media). But because the coefficients are
> under/barely-resolved, you won't see any benefit from high order DG, in
> which case you're just using a complicated/expensive method versus
> H(div) finite elements (perhaps cast as finite volume or mimetic FD).
I was including H(div) elements in my cG world. Is this terminology wrong?
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161004/b3d872b2/attachment-0001.html>
