[petsc-users] DG within DMPlex
Jed Brown jed at jedbrown.org
Tue Oct 4 10:43:18 CDT 2016
Matthew Knepley <knepley at gmail.com> writes:
>> > On Mon, Oct 3, 2016 at 9:51 PM, Praveen C <cpraveen at gmail.com> wrote:
>> >> DG for elliptic operators still makes lot of  sense if you have
>> >> problems with discontinuous coefficients
>> > This is thrown around a lot, but without justification. Why is it better
>> > for discontinuous coefficients? The
>> > solution is smoother than the coefficient (elliptic regularity). Are DG
>> > bases more efficient than high order
>> > cG for this problem? I have never seen anything convincing.
>> CG is non-monotone and the artifacts are often pretty serious for
>> high-contrast coefficients, especially when you're interested in
>> gradients (flow in porous media).  But because the coefficients are
>> under/barely-resolved, you won't see any benefit from high order DG, in
>> which case you're just using a complicated/expensive method versus
>> H(div) finite elements (perhaps cast as finite volume or mimetic FD).
> I was including H(div) elements in my cG world. Is this terminology wrong?
It's not a continuous basis....
Perhaps ambiguous.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161004/22ede0e7/attachment.pgp>
