[petsc-users] DG within DMPlex
Jed Brown
jed at jedbrown.org
Tue Oct 4 10:23:56 CDT 2016
Matthew Knepley <knepley at gmail.com> writes:
> On Mon, Oct 3, 2016 at 9:51 PM, Praveen C <cpraveen at gmail.com> wrote:
>> DG for elliptic operators still makes lot of sense if you have
>> problems with discontinuous coefficients
> This is thrown around a lot, but without justification. Why is it better
> for discontinuous coefficients? The
> solution is smoother than the coefficient (elliptic regularity). Are DG
> bases more efficient than high order
> cG for this problem? I have never seen anything convincing.
CG is non-monotone and the artifacts are often pretty serious for
high-contrast coefficients, especially when you're interested in
gradients (flow in porous media). But because the coefficients are
under/barely-resolved, you won't see any benefit from high order DG, in
which case you're just using a complicated/expensive method versus
H(div) finite elements (perhaps cast as finite volume or mimetic FD).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161004/0aeb0375/attachment.pgp>
