[petsc-users] KSPSetUp with PETSc/MUMPS
Hong hzhang at mcs.anl.gov
Wed May 25 11:43:16 CDT 2016
Constantin:
I can reproduce your report, and am trying to debug it.
One thing I found is memory problem. With one processor on o-build,
I get
$ valgrind --tool=memcheck ./ex51f
==28659== Memcheck, a memory error detector
==28659== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et al.
==28659== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright info
==28659== Command: ./ex51f
==28659==
 BEGIN PROC           0
 ITERATION           1
==28659== Invalid write of size 4
==28659==    at 0x509B519: matload_ (in
/scratch/hzhang/petsc/arch-linux-gcc-gfortran-o/lib/libpetsc.so.3.07.1)
==28659==    by 0x402204: MAIN__ (in
/scratch/hzhang/petsc/src/ksp/ksp/examples/tests/ex51f)
==28659==    by 0x4030DC: main (in
==28659==  Address 0xe is not stack'd, malloc'd or (recently) free'd
g-build does not show this error, plenty memory leak though.
I'm further investing it...
Hong
> I'm a new user of PETSc and I try to use it with MUMPS functionalities to
> compute a nullbasis.
> I wrote a code where I compute 4 times the same nullbasis. It does work
> well when I run it with several procs but with only one processor I get an
> error on the 2nd iteration when KSPSetUp is called. Furthermore when it is
> run with a debugger ( --with-debugging=yes), it works fine with one or
> several processors.
> Have you got any idea about why it doesn't work with one processor and no
> debugger?
> Thanks.
> Constantin.
> PS: You can find the code and the files required to run it enclosed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160525/f2370dfe/attachment.html>
