[petsc-users] KSPSetUp with PETSc/MUMPS
Constantin Nguyen Van constantin.nguyen.van at openmailbox.org
Wed May 25 02:40:57 CDT 2016
I'm a new user of PETSc and I try to use it with MUMPS functionalities
to compute a nullbasis.
I wrote a code where I compute 4 times the same nullbasis. It does work
well when I run it with several procs but with only one processor I get
an error on the 2nd iteration when KSPSetUp is called. Furthermore when
it is run with a debugger ( --with-debugging=yes), it works fine with
one or several processors.
Have you got any idea about why it doesn't work with one processor and
no debugger?
Thanks.
Constantin.
PS: You can find the code and the files required to run it enclosed.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160525/87cadecd/attachment.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160525/87cadecd/attachment.ksh>
Type: text/x-c
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160525/87cadecd/attachment.bin>
