[petsc-users] KSPSetUp with PETSc/MUMPS
Wed May 25 11:52:02 CDT 2016
   call PetscViewerBinaryOpen(PETSC_COMM_WORLD, "mat_c_bin.txt", 0, viewer, ierr)
This looks buggy. It should be:
   call PetscViewerBinaryOpen(PETSC_COMM_WORLD, "mat_c_bin.txt", FILE_MODE_READ, viewer, ierr)
Satish
On Wed, 25 May 2016, Hong wrote:
> Constantin:
> I can reproduce your report, and am trying to debug it.
> One thing I found is memory problem. With one processor on o-build,
> I get
> $ valgrind --tool=memcheck ./ex51f
> ==28659== Memcheck, a memory error detector
> ==28659== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et al.
> ==28659== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright info
> ==28659== Command: ./ex51f
> ==28659==
>  BEGIN PROC           0
>  ITERATION           1
> ==28659== Invalid write of size 4
> ==28659==    at 0x509B519: matload_ (in
> /scratch/hzhang/petsc/arch-linux-gcc-gfortran-o/lib/libpetsc.so.3.07.1)
> ==28659==    by 0x402204: MAIN__ (in
> /scratch/hzhang/petsc/src/ksp/ksp/examples/tests/ex51f)
> ==28659==    by 0x4030DC: main (in
> ==28659==  Address 0xe is not stack'd, malloc'd or (recently) free'd
> g-build does not show this error, plenty memory leak though.
> I'm further investing it...
> Hong
> Hi,
> > I'm a new user of PETSc and I try to use it with MUMPS functionalities to
> > compute a nullbasis.
> > I wrote a code where I compute 4 times the same nullbasis. It does work
> > well when I run it with several procs but with only one processor I get an
> > error on the 2nd iteration when KSPSetUp is called. Furthermore when it is
> > run with a debugger ( --with-debugging=yes), it works fine with one or
> > several processors.
> > Have you got any idea about why it doesn't work with one processor and no
> > debugger?
> > Thanks.
> > Constantin.
> > PS: You can find the code and the files required to run it enclosed.
