[petsc-users] ISGetTotalIndices with Fortran
Barry Smith
bsmith at mcs.anl.gov
Mon Jun 27 21:54:14 CDT 2016
I have added these fortran interfaces in the branch barry/add-missing-apis/maint and merged into the next branch for testing. When it passes the tests I will merge it into maint and it will then be available in the next patch release.
Barry
> On Jun 27, 2016, at 7:50 AM, Constantin Nguyen Van <constantin.nguyen.van at openmailbox.org> wrote:
> Hi,
> I'm tring to use ISGetTotalIndices in a Fortran program but I've got an undefined reference error message when I compile it :"undefined reference to `isgettotalindices_'".
> I've also tried to replace IsGetIndices by ISGetTotalIndices and also ISGetNonlocalIndices in this example http://www.mcs.anl.gov/petsc/petsc-current/src/vec/is/is/examples/tutorials/ex1f.F.html but the same error occurs.
> The "nm /lib/libpetsc.so |grep ISGetTotal" command returns "000000000031a7ab T ISGetTotalIndices" so that the symbol is there and nothing seems to be missing.
> Are those routines available in Fortran?
> Thank you.
> Constantin.
