[petsc-users] ISGetTotalIndices with Fortran
Constantin Nguyen Van constantin.nguyen.van at openmailbox.org
Tue Jun 28 09:51:38 CDT 2016
Alright!
Thank you.
Constantin.
Le 2016-06-28 04:54, Barry Smith a écrit :
> I have added these fortran interfaces in the branch
> barry/add-missing-apis/maint and merged into the next branch for
> testing. When it passes the tests I will merge it into maint and it
> will then be available in the next patch release.
>    Barry
>> On Jun 27, 2016, at 7:50 AM, Constantin Nguyen Van
>> <constantin.nguyen.van at openmailbox.org> wrote:
>> Hi,
>> I'm tring to use ISGetTotalIndices in a Fortran program but I've got
>> an undefined reference error message when I compile it :"undefined
>> reference to `isgettotalindices_'".
>> I've also tried to replace IsGetIndices by ISGetTotalIndices and also
>> ISGetNonlocalIndices in this example
>> http://www.mcs.anl.gov/petsc/petsc-current/src/vec/is/is/examples/tutorials/ex1f.F.html
>> but the same error occurs.
>> The "nm /lib/libpetsc.so |grep ISGetTotal" command returns
>> "000000000031a7ab T ISGetTotalIndices" so that the symbol is there and
>> nothing seems to be missing.
>> Are those routines available in Fortran?
>> Thank you.
>> Constantin.
