[petsc-users] undefined symbol: mpi_init_
Antonio Trande anto.trande at gmail.com
Sat Jun 25 14:41:54 CDT 2016
On 06/25/2016 03:59 PM, Matthew Knepley wrote:
> On Sat, Jun 25, 2016 at 8:21 AM, Antonio Trande <anto.trande at gmail.com
> <mailto:anto.trande at gmail.com>> wrote:
>     Hi all,
>     is it possible to compile serial PETSc library ?
>     I'm trying to compile PETSc without MPI by configuring with options:
>      --with-mpi=0 --with-mpiuni-fortran-binding=0
>     but compiler uses -I/.../petsc-3.7.2/include/petsc/mpiuni flag anyway
>     and libpetsc.so contains an "undefined symbol":
>     undefined symbol: mpi_init_     (/usr/lib64/libpetsc.so.3.7.2)
>     How I can fix this issue ?
>     Full log:
>     https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00362302-petsc/build.log.gz
> 1) Why are you giving --with-mpiuni-fortran-binding=0 if you still have
> Fortran turned on? If you want to turn off Fortran, use --with-fc=0.
I did't know what it does. If I active --with-mpiuni-fortran-binding,
'undefined symbol' disappears.
> 2) You did not send configure.log which is what I need, not a screen
> capture.
> 3) I cannot see the error you sent anywhere. It would be more useful to
> send the output from 'make test'.
>   Matt
I send you all config.log; petsc-serial, petsc-serial (64bit integer),
petsc-openmpi and petsc-mpich are compiled from an own fresh source
directory, respectively from petsc-3.7.2, build64, buildopenmpi_dir,
buildmpich_dir.
All libraries look compiled fine and related test passed.
I will send you latest builds log from Fedora Copr build-system.
Antonio Trande
mailto: sagitter 'at' fedoraproject 'dot' org
http://fedoraos.wordpress.com/
https://fedoraproject.org/wiki/User:Sagitter
GPG Key: 0x6CE6D08A
Check on https://keys.fedoraproject.org/
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160625/20170f25/attachment-0001.zip>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160625/20170f25/attachment-0001.pgp>
