[petsc-users] undefined symbol: mpi_init_
Matthew Knepley
knepley at gmail.com
Sat Jun 25 08:59:50 CDT 2016
On Sat, Jun 25, 2016 at 8:21 AM, Antonio Trande <anto.trande at gmail.com>
wrote:
> Hi all,
> is it possible to compile serial PETSc library ?
> I'm trying to compile PETSc without MPI by configuring with options:
> --with-mpi=0 --with-mpiuni-fortran-binding=0
> but compiler uses -I/.../petsc-3.7.2/include/petsc/mpiuni flag anyway
> and libpetsc.so contains an "undefined symbol":
> undefined symbol: mpi_init_ (/usr/lib64/libpetsc.so.3.7.2)
> How I can fix this issue ?
> Full log:
> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00362302-petsc/build.log.gz
1) Why are you giving --with-mpiuni-fortran-binding=0 if you still have
Fortran turned on? If you want to turn off Fortran, use --with-fc=0.
2) You did not send configure.log which is what I need, not a screen
capture.
3) I cannot see the error you sent anywhere. It would be more useful to
send the output from 'make test'.
Matt
> Antonio Trande
> mailto: sagitter 'at' fedoraproject 'dot' org
> http://fedoraos.wordpress.com/
> https://fedoraproject.org/wiki/User:Sagitter
> GPG Key: 0x6CE6D08A
> Check on https://keys.fedoraproject.org/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160625/10f14e57/attachment.html>
