[petsc-users] Fwd: Re: Error with PETSc on K computer
Thu Jun 9 22:00:00 CDT 2016
  Without knowing the specifics of how this machine's Fortran compiler passes Fortran pointers to subroutines we cannot resolve this problem. This information can only be obtained from the experts on the this machine.
   Barry
> On Jun 9, 2016, at 9:28 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> The current solution cannot work. May I know if there's any other solution to try. Meanwhile, I've also email the K computer helpdesk for help.
> Thank you
> Yours sincerely,
> TAY wee-beng
> On 3/6/2016 10:33 PM, Satish Balay wrote:
>> Sorry - I'm not sure whats hapenning with this compiler.
>> [for a build without the patch I sent ] - can you edit
>> PETSC_ARCH/include/petscconf.h and remove the lines
>> #ifndef PETSC_HAVE_F90_2PTR_ARG
>> #define PETSC_HAVE_F90_2PTR_ARG 1
>> #endif
>> And then build the libraries [do not run configure again].
>> Does this make a difference for this example?
>> Satish
>> On Fri, 3 Jun 2016, TAY wee-beng wrote:
>>> Hi,
>>> Is there any update to the issue below?
>>> No hurry, just to make sure that the email is sent successfully.
>>> Thanks
>>> -------- Forwarded Message --------
>>> Subject: 	Re: [petsc-users] Error with PETSc on K computer
>>> Date: 	Thu, 2 Jun 2016 10:25:22 +0800
>>> From: 	TAY wee-beng <zonexo at gmail.com>
>>> To: 	petsc-users <petsc-users at mcs.anl.gov>
>>> Hi Satish,
>>> The X9 option is :
>>> Provides a different interpretation under Fortran 95 specifications
>>> for any parts not conforming to the language specifications of this
>>> compiler
>>> I just patched and re-compiled but it still can't work. I've attached the
>>> configure.log for both builds.
>>> FYI, some parts of the PETSc 3.6.3 code were initially patch to make it work
>>> with the K computer system:
>>> $ diff -u petsc-3.6.3/config/BuildSystem/config/package.py.org
>>> --- petsc-3.6.3/config/BuildSystem/config/package.py.org 2015-12-04
>>> 14:06:42.000000000 +0900
>>> +++ petsc-3.6.3/config/BuildSystem/config/package.py 2016-01-22
>>> 11:09:37.000000000 +0900
>>> @@ -174,7 +174,7 @@
>>>      return ''
>>>    def getSharedFlag(self,cflags):
>>> -    for flag in ['-PIC', '-fPIC', '-KPIC', '-qpic']:
>>> +    for flag in ['-KPIC', '-fPIC', '-PIC', '-qpic']:
>>>        if cflags.find(flag) >=0: return flag
>>>      return ''
>>> $ diff -u petsc-3.6.3/config/BuildSystem/config/setCompilers.py.org
>>> --- petsc-3.6.3/config/BuildSystem/config/setCompilers.py.org 2015-07-23
>>> 00:22:46.000000000 +0900
>>> +++ petsc-3.6.3/config/BuildSystem/config/setCompilers.py 2016-01-22
>>> 11:10:05.000000000 +0900
>>> @@ -1017,7 +1017,7 @@
>>>        self.pushLanguage(language)
>>>        #different compilers are sensitive to the order of testing these
>>> flags. So separete out GCC test.
>>>        if config.setCompilers.Configure.isGNU(self.getCompiler()): testFlags =
>>> ['-fPIC']
>>> -      else: testFlags = ['-PIC', '-fPIC', '-KPIC','-qpic']
>>> +      else: testFlags = ['-KPIC', '-fPIC', '-PIC','-qpic']
>>>        for testFlag in testFlags:
>>>          try:
>>>            self.logPrint('Trying '+language+' compiler flag '+testFlag)
>>> $ diff -u petsc-3.6.3/config/BuildSystem/config/packages/openmp.py.org
>>> --- petsc-3.6.3/config/BuildSystem/config/packages/openmp.py.org 2016-01-25
>>> 15:42:23.000000000+0900
>>> +++ petsc-3.6.3/config/BuildSystem/config/packages/openmp.py 2016-01-22
>>> 17:13:52.000000000 +0900
>>> @@ -19,7 +19,8 @@
>>>      self.found = 0
>>>      self.setCompilers.pushLanguage('C')
>>> -    for flag in ["-fopenmp", # Gnu
>>> +    for flag in ["-Kopenmp", # Fujitsu
>>> +                 "-fopenmp", # Gnu
>>>                   "-qsmp=omp",# IBM XL C/C++
>>>                   "-h omp",   # Cray. Must come after XL because XL
>>> interprets this option as meaning"-soname omp"
>>>                   "-mp",      # Portland Group
>>> $ diff -u ./petsc-3.6.3/config/BuildSystem/config/compilers.py.org
>>> --- ./petsc-3.6.3/config/BuildSystem/config/compilers.py.org 2015-06-10
>>> 06:24:49.000000000 +0900
>>> +++ ./petsc-3.6.3/config/BuildSystem/config/compilers.py 2016-02-19
>>> 11:56:12.000000000 +0900
>>> @@ -164,7 +164,7 @@
>>>    def checkCLibraries(self):
>>>      '''Determines the libraries needed to link with C'''
>>>      oldFlags = self.setCompilers.LDFLAGS
>>> -    self.setCompilers.LDFLAGS += ' -v'
>>> +    self.setCompilers.LDFLAGS += ' -###'
>>>      self.pushLanguage('C')
>>>      (output, returnCode) = self.outputLink('', '')
>>>      self.setCompilers.LDFLAGS = oldFlags
>>> @@ -413,7 +413,7 @@
>>>    def checkCxxLibraries(self):
>>>      '''Determines the libraries needed to link with C++'''
>>>      self.pushLanguage('Cxx')
>>> Thank you
>>> Yours sincerely,
>>> TAY wee-beng
>>> On 2/6/2016 3:18 AM, Satish Balay wrote:
>>>> What does -X9 in  --FFLAGS="-X9 -O0" do?
>>>> can you send configure.log for this build?
>>>> And does the attached patch make a difference with this example?
>>>> [suggest doing a separate temporary build of PETSc - in a different source
>>>> location - to check this.]
>>>> Satish
>>>> On Wed, 1 Jun 2016, TAY wee-beng wrote:
>>>>> Hi Satish,
>>>>> Only partially working:
>>>>> [t00196 at b04-036 tutorials]$ mpiexec -n 2 ./ex4f90
>>>>> jwe1050i-w The hardware barrier couldn't be used and continues processing
>>>>> using the software barrier.
>>>>> taken to (standard) corrective action, execution continuing.
>>>>> Vec Object:Vec Object:initial vector:initial vector: 1 MPI processes
>>>>>    type: seq
>>>>> 10
>>>>> 20
>>>>> 30
>>>>> 40
>>>>> 50
>>>>> 60
>>>>>   1 MPI processes
>>>>>    type: seq
>>>>> 10
>>>>> 20
>>>>> 30
>>>>> 40
>>>>> 50
>>>>> 60
>>>>> [1]PETSC ERROR:
>>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>>> probably
>>>>> memory access out of range
>>>>> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [1]PETSC ERROR: or see
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>> [1]PETSC ERROR: or tryhttp://valgrind.org  on GNU/linux and Apple Mac OS X
>>>>> to
>>>>> find memory corruption errors
>>>>> [1]PETSC ERROR: likely location of problem given in stack below
>>>>> [1]PETSC ERROR: ---------------------  Stack Frames
>>>>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>> available,
>>>>> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [1]PETSC ERROR:       is given.
>>>>> [1]PETSC ERROR: [1] F90Array1dCreate line 50
>>>>> /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/src/sys/f90-src/f90_cwrap.c
>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>> ------------------------------------------[0]PETSC ERROR:
>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>>> probably
>>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [0]PETSC ERROR: or see
>>>>> [0]PETSC ERROR: or tryhttp://valgrind.org  on GNU/linux and Apple Mac OS X
>>>>> to
>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>> available,
>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [0]PETSC ERROR:       is given.
>>>>> [0]PETSC ERROR: [0] F90Array1dCreate line 50
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [1]PETSC ERROR: Signal received
>>>>> [1]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>> for
>>>>> trouble shooting.
>>>>> [1]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>>>> [1]PETSC ERROR: ./ex4f90 on a petsc-3.6.3_debug named b04-036 by Unknown
>>>>> Wed
>>>>> Jun  1 13:23:41 2016
>>>>> [1]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>>> --with-fc=mpifrt --with-64-bit-pointers=1 --CC=mpifcc --CFLAGS="-Xg -O0"
>>>>> --CXX=mpiFCC --CXXFLAGS="-Xg -O0" --FC=mpifrt --FFLAGS="-X9 -O0"
>>>>> --LD_SHARED=
>>>>> --LDDFLAGS= --with-openmp=1 --with-mpiexec=mpiexec --known-endian=big
>>>>> --with-shared-libraries=0 --with-blas-lapack-lib=-SSL2
>>>>> --with-scalapack-lib=-SCALAPACK
>>>>> --prefix=/home/hp150306/t00196/lib/petsc-3.6.3_debug
>>>>> --with-fortran-interfaces=1 --with-debugging=1 --useThreads=0
>>>>> --with-hypre=1
>>>>> --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4
>>>>> [1]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>>> [mpi::mpi-api::mpi-abort]
>>>>> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
>>>>> with errorcode 59.
>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>>> You may or may not see output from other processes, depending on
>>>>> exactly when Open MPI kills them.
>>>>> [b04-036:28998]
>>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84)
>>>>> [0xffffffff11360404]
>>>>> [b04-036:28998]
>>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(ompi_mpi_abort+0x51c)
>>>>> [0xffffffff1110391c]
>>>>> [b04-036:28998]
>>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(MPI_Abort+0x6c)
>>>>> [0xffffffff1111b5ec]
>>>>> [b04-036:28998]
>>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libtrtmet_c.so.1(MPI_Abort+0x2c)
>>>>> [0xffffffff00281bf0]
>>>>> [b04-036:28998] ./ex4f90 [0x292548]
>>>>> [b04-036:28998] ./ex4f90 [0x29165c]
>>>>> [b04-036:28998]
>>>>> /opt/FJSVxosmmm/lib64/libmpgpthread.so.1(_IO_funlockfile+0x5c)
>>>>> [0xffffffff121e1974]
>>>>> [b04-036:28998] ./ex4f90 [0x9f6748]
>>>>> [b04-036:28998] ./ex4f90 [0x9f0ea4]
>>>>> [b04-036:28998] ./ex4f90 [0x2c76a0]
>>>>> [b04-036:28998] ./ex4f90(MAIN__+0x38c) [0x10688c]
>>>>> [b04-036:28998] ./ex4f90(main+0xec) [0x268e91c]
>>>>> [b04-036:28998] /lib64/libc.so.6(__libc_start_main+0x194)
>>>>> [0xffffffff138cb81c]
>>>>> [b04-036:28998] ./ex4f90 [0x1063ac]
>>>>> [1]PETSC ERROR:
>>>>> [1]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>>>> batch
>>>>> system) has told this process to end
>>>>> [1]PETSC ERROR: Tr--------------------
>>>>> [0]PETSC ERROR: Signal received
>>>>> [0]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>> for
>>>>> trouble shooting.
>>>>> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>>>> [0]PETSC ERROR: ./ex4f90 on a petsc-3.6.3_debug named b04-036 by Unknown
>>>>> Wed
>>>>> Jun  1 13:23:41 2016
>>>>> [0]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>>> --LD_SHARED=
>>>>> --with-hypre=1
>>>>> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>>> with errorcode 59.
>>>>> [b04-036:28997]
>>>>> [b04-036:28997]
>>>>> [b04-036:28997]
>>>>> [b04-036:28997]
>>>>> [b04-036:28997] ./ex4f90 [0x292548]
>>>>> [b04-036:28997] ./ex4f90 [0x29165c]
>>>>> [b04-036:28997]
>>>>> [b04-036:28997] ./ex4f90 [0x9f6748]
>>>>> [b04-036:28997] ./ex4f90 [0x9f0ea4]
>>>>> [b04-036:28997] ./ex4f90 [0x2c76a0]
>>>>> [b04-036:28997] ./ex4f90(MAIN__+0x38c) [0x10688c]
>>>>> [b04-036:28997] ./ex4f90(main+0xec) [0x268e91c]
>>>>> [b04-036:28997] /lib64/libc.so.6(__libc_start_main+0x194)
>>>>> [b04-036:28997] ./ex4f90 [0x1063ac]
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>>>> batch
>>>>> to
>>>>> available,
>>>>> for
>>>>> trouble shooting.
>>>>> Wed
>>>>> Jun  1 13:23:41 2016
>>>>> --LD_SHARED=
>>>>> --with-fortran-interfaces=1 --with-debuy option -start_in_debugger or
>>>>> to
>>>>> available,
>>>>> for
>>>>> trouble shooting.
>>>>> Wed
>>>>> Jun  1 13:23:41 2016
>>>>> --LD_SHARED=
>>>>> --with-hypre=1
>>>>> [1]PETSC ERROR: #2 User provided function() line 0 in  unknown file
>>>>> gging=1 --useThreads=0 --with-hypre=1
>>>>> [0]PETSC ERROR: #2 User provided function() line 0 in  unknown file
>>>>> [ERR.] PLE 0019 plexec One of MPI processes was
>>>>> aborted.(rank=0)(nid=0x04180034)(CODE=1938,793745140674134016,15104)
>>>>> [ERR.] PLE 0021 plexec The interactive job has aborted with the
>>>>> signal.(sig=24)
>>>>> [INFO] PJM 0083 pjsub Interactive job 5211401 completed.
>>>>> Thank you
>>>>> Yours sincerely,
>>>>> TAY wee-beng
>>>>> On 1/6/2016 12:21 PM, Satish Balay wrote:
>>>>>> Do PETSc examples using VecGetArrayF90() work?
>>>>>> say src/vec/vec/examples/tutorials/ex4f90.F
>>>>>> Satish
>>>>>> On Tue, 31 May 2016, TAY wee-beng wrote:
>>>>>>> Hi,
>>>>>>> I'm trying to run my MPI CFD code on Japan's K computer. My code can
>>>>>>> run
>>>>>>> if I
>>>>>>> didn't make use of the PETSc DMDAVecGetArrayF90 subroutine. If it's
>>>>>>> called
>>>>>>> call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>>>>>>> I get the error below.  I have no problem with my code on other
>>>>>>> clusters
>>>>>>> using
>>>>>>> the new Intel compilers. I used to have problems with DM when using
>>>>>>> the
>>>>>>> old
>>>>>>> Intel compilers. Now on the K computer, I'm using Fujitsu's Fortran
>>>>>>> compiler.
>>>>>>> How can I troubleshoot?
>>>>>>> Btw, I also tested on the ex13f90 example and it didn't work too. The
>>>>>>> error is
>>>>>>> below.
>>>>>>> My code error:
>>>>>>> /* size_x,size_y,size_z 76x130x136*//*
>>>>>>> *//* total grid size =  1343680*//*
>>>>>>> *//* recommended cores (50k / core) =  26.87360000000000*//*
>>>>>>> *//* 0*//*
>>>>>>> *//* 1*//*
>>>>>>> *//* 1*//*
>>>>>>> *//*[3]PETSC ERROR: [1]PETSC ERROR:
>>>>>>> *//*[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation,
>>>>>>> probably memory access out of range*//*
>>>>>>> *//*[1]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> -on_error_attach_debugger*//*
>>>>>>> *//*[1]PETSC ERROR: or see
>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind*//*
>>>>>>> *//*[1]PETSC ERROR: or tryhttp://valgrind.org  on GNU/linux and Apple
>>>>>>> Mac
>>>>>>> OS X
>>>>>>> to find memory corruption errors*//*
>>>>>>> *//*[1]PETSC ERROR: likely location of problem given in stack
>>>>>>> below*//*
>>>>>>> *//*[1]PETSC ERROR: ---------------------  Stack Frames
>>>>>>> *//*[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>> available,*//*
>>>>>>> *//*[1]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>> function*//*
>>>>>>> *//*[1]PETSC ERROR:       is given.*//*
>>>>>>> *//*[1]PETSC ERROR: [1] F90Array3dCreate line 244
>>>>>>> /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/src/sys/f90-src/f90_cwrap.c*//*
>>>>>>> *//* 1*//*
>>>>>>> *//*[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation,
>>>>>>> *//*[3]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> *//*[3]PETSC ERROR: or see
>>>>>>> *//*[3]PETSC ERROR: or tryhttp://valgrind.org  on GNU/linux and Apple
>>>>>>> Mac
>>>>>>> OS X
>>>>>>> *//*[3]PETSC ERROR: likely location of problem given in stack
>>>>>>> below*//*
>>>>>>> *//*[3]PETSC ERROR: ---------------------  Stack Frames
>>>>>>> *//*[0]PETSC ERROR:
>>>>>>> *//*[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation,
>>>>>>> *//*[0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> *//*[0]PETSC ERROR: or see
>>>>>>> *//*[0]PETSC ERROR: or tryhttp://valgrind.org  on GNU/linux and Apple
>>>>>>> Mac
>>>>>>> OS X
>>>>>>> *//*[0]PETSC ERROR: likely location of problem given in stack
>>>>>>> below*//*
>>>>>>> *//*[0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>> *//*[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>> available,*//*
>>>>>>> *//*[0]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>> function*//*
>>>>>>> *//*[0]PETSC ERROR:       is given.*//*
>>>>>>> *//*[0]PETSC ERROR: [0] F90Array3dCreate line 244
>>>>>>> *//*[0]PETSC ERROR: --------------------- Error Message
>>>>>>> ----------------------------------------- 1*//*
>>>>>>> *//*[2]PETSC ERROR:
>>>>>>> *//*[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation,
>>>>>>> *//*[2]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> *//*[2]PETSC ERROR: or see
>>>>>>> *//*[2]PETSC ERROR: or tryhttp://valgrind.org  on GNU/linux and Apple
>>>>>>> Mac
>>>>>>> OS X
>>>>>>> *//*[2]PETSC ERROR: likely location of problem given in stack
>>>>>>> below*//*
>>>>>>> *//*[2]PETSC ERROR: ---------------------  Stack Frames
>>>>>>> *//*[2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>> available,*//*
>>>>>>> *//*[2]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>> function*//*
>>>>>>> *//*[2]PETSC ERROR:       is given.*//*
>>>>>>> *//*[2]PETSC ERROR: [2] F90Array3dCreate line 244
>>>>>>> *//*[2]PETSC ERROR: --------------------- Error Message
>>>>>>> -----------------------------------------[3]PETSC ERROR: Note: The
>>>>>>> EXACT
>>>>>>> line
>>>>>>> numbers in the stack are not available,*//*
>>>>>>> *//*[3]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>> function*//*
>>>>>>> *//*[3]PETSC ERROR:       is given.*//*
>>>>>>> *//*[3]PETSC ERROR: [3] F90Array3dCreate line 244
>>>>>>> *//*[3]PETSC ERROR: --------------------- Error Message
>>>>>>> *//*[3]PETSC ERROR: Signal received*//*
>>>>>>> *//*[3]PETSC ERROR: See
>>>>>>> for trouble shooting.*//*
>>>>>>> *//*[3]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>>> *//*[3]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>>> by
>>>>>>> Unknown Wed Jun  1 12:54:34 2016*//*
>>>>>>> *//*[3]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>>> --with-cxx=mpiFCC
>>>>>>> -O0"
>>>>>>> --LD_SHARED=
>>>>>>> --with-shared----------------------*//*
>>>>>>> *//*[0]PETSC ERROR: Signal received*//*
>>>>>>> *//*[0]PETSC ERROR: See
>>>>>>> *//*[0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>>> *//*[0]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>>> by
>>>>>>> *//*[0]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>>> --with-cxx=mpiFCC
>>>>>>> -O0"
>>>>>>> --LD_SHARED=
>>>>>>> --with-hypre=1
>>>>>>> --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4*//*
>>>>>>> *//*[0]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>> file*//*
>>>>>>> *//*[m---------------------*//*
>>>>>>> *//*[2]PETSC ERROR: Signal received*//*
>>>>>>> *//*[2]PETSC ERROR: See
>>>>>>> *//*[2]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>>> *//*[2]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>>> by
>>>>>>> *//*[2]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>>> --with-cxx=mpiFCC
>>>>>>> -O0"
>>>>>>> --LD_SHARED=
>>>>>>> --with-hypre=1
>>>>>>> *//*[2]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>> file*//*
>>>>>>> *//*[m[1]PETSC ERROR: --------------------- Error Message
>>>>>>> *//*[1]PETSC ERROR: Signal received*//*
>>>>>>> *//*[1]PETSC ERROR: See
>>>>>>> *//*[1]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>>> *//*[1]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>>> by
>>>>>>> *//*[1]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>>> --with-cxx=mpiFCC
>>>>>>> -O0"
>>>>>>> --LD_SHARED=
>>>>>>> --with-hypre=1
>>>>>>> *//*[1]PETSC ERROR: #1 User provided function() line 0 ilibraries=0
>>>>>>> --with-blas-lapack-lib=-SSL2 --with-scalapack-lib=-SCALAPACK
>>>>>>> --with-hypre=1
>>>>>>> *//*[3]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>> file*//*
>>>>>>> *//*[mpi::mpi-api::mpi-abort]*//*
>>>>>>> *//*MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD*//*
>>>>>>> *//*with errorcode 59.*//*
>>>>>>> *//*NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>>>>>> processes.*//*
>>>>>>> *//*You may or may not see output from other processes, depending
>>>>>>> on*//*
>>>>>>> *//*exactly when Open MPI kills them.*//*
>>>>>>> *//*[b04-036:28416]
>>>>>>> [0xffffffff11360404]*//*
>>>>>>> *//*[b04-036:28416]
>>>>>>> [0xffffffff1110391c]*//*
>>>>>>> *//*[b04-036:28416]
>>>>>>> /opt/FJSVtclang/GM-1.2.0-2pi::mpi-api::mpi-abort]*//*
>>>>>>> *//*MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD*//*
>>>>>>> ex13f90 error:
>>>>>>> /*[t00196 at b04-036 tutorials]$ mpiexec -np 2 ./ex13f90*//*
>>>>>>> *//*jwe1050i-w The hardware barrier couldn't be used and continues
>>>>>>> processing
>>>>>>> using the software barrier.*//*
>>>>>>> *//*taken to (standard) corrective action, execution continuing.*//*
>>>>>>> processing
>>>>>>> *//* Hi! We're solving van der Pol using  2 processes.*//*
>>>>>>> *//*   t     x1         x2*//*
>>>>>>> *//*[1]PETSC ERROR:
>>>>>>> *//*[1]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly
>>>>>>> illegal
>>>>>>> memory access*//*
>>>>>>> *//*[0]PETSC ERROR:
>>>>>>> *//*[0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly
>>>>>>> illegal
>>>>>>> memory access*//*
>>>>>>> Mac
>>>>>>> OS X
>>>>>>> Mac
>>>>>>> OS X
>>>>>>> below*//*
>>>>>>> available,*//*
>>>>>>> function*//*
>>>>>>> *//*[1]PETSC ERROR: [1] F90Array4dCreate line 337
>>>>>>> below*//*
>>>>>>> available,*//*
>>>>>>> function*//*
>>>>>>> *//*[0]PETSC ERROR: [0] F90Array4dCreate line 337
>>>>>>> *//*[1]PETSC ERROR: --------------------- Error Message
>>>>>>> *//*[1]PETSC ERROR: ./ex13f90 on a petsc-3.6.3_debug named b04-036 by
>>>>>>> Unknown
>>>>>>> Wed Jun  1 13:04:34 2016*//*
>>>>>>> --with-cxx=mpiFCC
>>>>>>> -O0"
>>>>>>> --LD_SHARED=
>>>>>>> --with-hypre=1
>>>>>>> --with-hyp*//*
