[petsc-users] Fwd: Re: Error with PETSc on K computer
TAY wee-beng
zonexo at gmail.com
Thu Jun 9 21:28:55 CDT 2016
The current solution cannot work. May I know if there's any other
solution to try. Meanwhile, I've also email the K computer helpdesk for
help.
Thank you
Yours sincerely,
TAY wee-beng
On 3/6/2016 10:33 PM, Satish Balay wrote:
> Sorry - I'm not sure whats hapenning with this compiler.
> [for a build without the patch I sent ] - can you edit
> PETSC_ARCH/include/petscconf.h and remove the lines
> #ifndef PETSC_HAVE_F90_2PTR_ARG
> #define PETSC_HAVE_F90_2PTR_ARG 1
> #endif
> And then build the libraries [do not run configure again].
> Does this make a difference for this example?
> Satish
> On Fri, 3 Jun 2016, TAY wee-beng wrote:
>> Hi,
>> Is there any update to the issue below?
>> No hurry, just to make sure that the email is sent successfully.
>> Thanks
>> -------- Forwarded Message --------
>> Subject: Re: [petsc-users] Error with PETSc on K computer
>> Date: Thu, 2 Jun 2016 10:25:22 +0800
>> From: TAY wee-beng <zonexo at gmail.com>
>> To: petsc-users <petsc-users at mcs.anl.gov>
>> Hi Satish,
>> The X9 option is :
>> Provides a different interpretation under Fortran 95 specifications
>> for any parts not conforming to the language specifications of this
>> compiler
>> I just patched and re-compiled but it still can't work. I've attached the
>> configure.log for both builds.
>> FYI, some parts of the PETSc 3.6.3 code were initially patch to make it work
>> with the K computer system:
>> $ diff -u petsc-3.6.3/config/BuildSystem/config/package.py.org
>> --- petsc-3.6.3/config/BuildSystem/config/package.py.org 2015-12-04
>> 14:06:42.000000000 +0900
>> +++ petsc-3.6.3/config/BuildSystem/config/package.py 2016-01-22
>> 11:09:37.000000000 +0900
>> @@ -174,7 +174,7 @@
>> return ''
>> def getSharedFlag(self,cflags):
>> - for flag in ['-PIC', '-fPIC', '-KPIC', '-qpic']:
>> + for flag in ['-KPIC', '-fPIC', '-PIC', '-qpic']:
>> if cflags.find(flag) >=0: return flag
>> return ''
>> $ diff -u petsc-3.6.3/config/BuildSystem/config/setCompilers.py.org
>> --- petsc-3.6.3/config/BuildSystem/config/setCompilers.py.org 2015-07-23
>> 00:22:46.000000000 +0900
>> +++ petsc-3.6.3/config/BuildSystem/config/setCompilers.py 2016-01-22
>> 11:10:05.000000000 +0900
>> @@ -1017,7 +1017,7 @@
>> self.pushLanguage(language)
>> #different compilers are sensitive to the order of testing these
>> flags. So separete out GCC test.
>> if config.setCompilers.Configure.isGNU(self.getCompiler()): testFlags =
>> ['-fPIC']
>> - else: testFlags = ['-PIC', '-fPIC', '-KPIC','-qpic']
>> + else: testFlags = ['-KPIC', '-fPIC', '-PIC','-qpic']
>> for testFlag in testFlags:
>> try:
>> self.logPrint('Trying '+language+' compiler flag '+testFlag)
>> $ diff -u petsc-3.6.3/config/BuildSystem/config/packages/openmp.py.org
>> --- petsc-3.6.3/config/BuildSystem/config/packages/openmp.py.org 2016-01-25
>> 15:42:23.000000000+0900
>> +++ petsc-3.6.3/config/BuildSystem/config/packages/openmp.py 2016-01-22
>> 17:13:52.000000000 +0900
>> @@ -19,7 +19,8 @@
>> self.found = 0
>> self.setCompilers.pushLanguage('C')
>> - for flag in ["-fopenmp", # Gnu
>> + for flag in ["-Kopenmp", # Fujitsu
>> + "-fopenmp", # Gnu
>> "-qsmp=omp",# IBM XL C/C++
>> "-h omp", # Cray. Must come after XL because XL
>> interprets this option as meaning"-soname omp"
>> "-mp", # Portland Group
>> $ diff -u ./petsc-3.6.3/config/BuildSystem/config/compilers.py.org
>> --- ./petsc-3.6.3/config/BuildSystem/config/compilers.py.org 2015-06-10
>> 06:24:49.000000000 +0900
>> +++ ./petsc-3.6.3/config/BuildSystem/config/compilers.py 2016-02-19
>> 11:56:12.000000000 +0900
>> @@ -164,7 +164,7 @@
>> def checkCLibraries(self):
>> '''Determines the libraries needed to link with C'''
>> oldFlags = self.setCompilers.LDFLAGS
>> - self.setCompilers.LDFLAGS += ' -v'
>> + self.setCompilers.LDFLAGS += ' -###'
>> self.pushLanguage('C')
>> (output, returnCode) = self.outputLink('', '')
>> self.setCompilers.LDFLAGS = oldFlags
>> @@ -413,7 +413,7 @@
>> def checkCxxLibraries(self):
>> '''Determines the libraries needed to link with C++'''
>> self.pushLanguage('Cxx')
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
>> On 2/6/2016 3:18 AM, Satish Balay wrote:
>>> What does -X9 in --FFLAGS="-X9 -O0" do?
>>> can you send configure.log for this build?
>>> And does the attached patch make a difference with this example?
>>> [suggest doing a separate temporary build of PETSc - in a different source
>>> location - to check this.]
>>> Satish
>>> On Wed, 1 Jun 2016, TAY wee-beng wrote:
>>>> Hi Satish,
>>>> Only partially working:
>>>> [t00196 at b04-036 tutorials]$ mpiexec -n 2 ./ex4f90
>>>> jwe1050i-w The hardware barrier couldn't be used and continues processing
>>>> using the software barrier.
>>>> taken to (standard) corrective action, execution continuing.
>>>> Vec Object:Vec Object:initial vector:initial vector: 1 MPI processes
>>>> type: seq
>>>> 10
>>>> 20
>>>> 30
>>>> 40
>>>> 50
>>>> 60
>>>> 1 MPI processes
>>>> type: seq
>>>> 10
>>>> 20
>>>> 30
>>>> 40
>>>> 50
>>>> 60
>>>> [1]PETSC ERROR:
>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably
>>>> memory access out of range
>>>> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [1]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>> [1]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac OS X
>>>> to
>>>> find memory corruption errors
>>>> [1]PETSC ERROR: likely location of problem given in stack below
>>>> [1]PETSC ERROR: --------------------- Stack Frames
>>>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,
>>>> [1]PETSC ERROR: INSTEAD the line number of the start of the function
>>>> [1]PETSC ERROR: is given.
>>>> [1]PETSC ERROR: [1] F90Array1dCreate line 50
>>>> /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/src/sys/f90-src/f90_cwrap.c
>>>> [1]PETSC ERROR: --------------------- Error Message
>>>> ------------------------------------------[0]PETSC ERROR:
>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably
>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see
>>>> [0]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac OS X
>>>> to
>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>> [0]PETSC ERROR: --------------------- Stack Frames
>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,
>>>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>>>> [0]PETSC ERROR: is given.
>>>> [0]PETSC ERROR: [0] F90Array1dCreate line 50
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [1]PETSC ERROR: Signal received
>>>> [1]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for
>>>> trouble shooting.
>>>> [1]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>>> [1]PETSC ERROR: ./ex4f90 on a petsc-3.6.3_debug named b04-036 by Unknown
>>>> Wed
>>>> Jun 1 13:23:41 2016
>>>> [1]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>> --with-fc=mpifrt --with-64-bit-pointers=1 --CC=mpifcc --CFLAGS="-Xg -O0"
>>>> --CXX=mpiFCC --CXXFLAGS="-Xg -O0" --FC=mpifrt --FFLAGS="-X9 -O0"
>>>> --LD_SHARED=
>>>> --LDDFLAGS= --with-openmp=1 --with-mpiexec=mpiexec --known-endian=big
>>>> --with-shared-libraries=0 --with-blas-lapack-lib=-SSL2
>>>> --with-scalapack-lib=-SCALAPACK
>>>> --prefix=/home/hp150306/t00196/lib/petsc-3.6.3_debug
>>>> --with-fortran-interfaces=1 --with-debugging=1 --useThreads=0
>>>> --with-hypre=1
>>>> --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4
>>>> [1]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>>> [mpi::mpi-api::mpi-abort]
>>>> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
>>>> with errorcode 59.
>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>> You may or may not see output from other processes, depending on
>>>> exactly when Open MPI kills them.
>>>> [b04-036:28998]
>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84)
>>>> [0xffffffff11360404]
>>>> [b04-036:28998]
>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(ompi_mpi_abort+0x51c)
>>>> [0xffffffff1110391c]
>>>> [b04-036:28998]
>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(MPI_Abort+0x6c)
>>>> [0xffffffff1111b5ec]
>>>> [b04-036:28998]
>>>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libtrtmet_c.so.1(MPI_Abort+0x2c)
>>>> [0xffffffff00281bf0]
>>>> [b04-036:28998] ./ex4f90 [0x292548]
>>>> [b04-036:28998] ./ex4f90 [0x29165c]
>>>> [b04-036:28998]
>>>> /opt/FJSVxosmmm/lib64/libmpgpthread.so.1(_IO_funlockfile+0x5c)
>>>> [0xffffffff121e1974]
>>>> [b04-036:28998] ./ex4f90 [0x9f6748]
>>>> [b04-036:28998] ./ex4f90 [0x9f0ea4]
>>>> [b04-036:28998] ./ex4f90 [0x2c76a0]
>>>> [b04-036:28998] ./ex4f90(MAIN__+0x38c) [0x10688c]
>>>> [b04-036:28998] ./ex4f90(main+0xec) [0x268e91c]
>>>> [b04-036:28998] /lib64/libc.so.6(__libc_start_main+0x194)
>>>> [0xffffffff138cb81c]
>>>> [b04-036:28998] ./ex4f90 [0x1063ac]
>>>> [1]PETSC ERROR:
>>>> [1]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>>> batch
>>>> system) has told this process to end
>>>> [1]PETSC ERROR: Tr--------------------
>>>> [0]PETSC ERROR: Signal received
>>>> [0]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for
>>>> trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>>> [0]PETSC ERROR: ./ex4f90 on a petsc-3.6.3_debug named b04-036 by Unknown
>>>> Wed
>>>> Jun 1 13:23:41 2016
>>>> [0]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>> --LD_SHARED=
>>>> --with-hypre=1
>>>> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>> with errorcode 59.
>>>> [b04-036:28997]
>>>> [b04-036:28997]
>>>> [b04-036:28997]
>>>> [b04-036:28997]
>>>> [b04-036:28997] ./ex4f90 [0x292548]
>>>> [b04-036:28997] ./ex4f90 [0x29165c]
>>>> [b04-036:28997]
>>>> [b04-036:28997] ./ex4f90 [0x9f6748]
>>>> [b04-036:28997] ./ex4f90 [0x9f0ea4]
>>>> [b04-036:28997] ./ex4f90 [0x2c76a0]
>>>> [b04-036:28997] ./ex4f90(MAIN__+0x38c) [0x10688c]
>>>> [b04-036:28997] ./ex4f90(main+0xec) [0x268e91c]
>>>> [b04-036:28997] /lib64/libc.so.6(__libc_start_main+0x194)
>>>> [b04-036:28997] ./ex4f90 [0x1063ac]
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>>> batch
>>>> to
>>>> available,
>>>> for
>>>> trouble shooting.
>>>> Wed
>>>> Jun 1 13:23:41 2016
>>>> --LD_SHARED=
>>>> --with-fortran-interfaces=1 --with-debuy option -start_in_debugger or
>>>> to
>>>> available,
>>>> for
>>>> trouble shooting.
>>>> Wed
>>>> Jun 1 13:23:41 2016
>>>> --LD_SHARED=
>>>> --with-hypre=1
>>>> [1]PETSC ERROR: #2 User provided function() line 0 in unknown file
>>>> gging=1 --useThreads=0 --with-hypre=1
>>>> [0]PETSC ERROR: #2 User provided function() line 0 in unknown file
>>>> [ERR.] PLE 0019 plexec One of MPI processes was
>>>> aborted.(rank=0)(nid=0x04180034)(CODE=1938,793745140674134016,15104)
>>>> [ERR.] PLE 0021 plexec The interactive job has aborted with the
>>>> signal.(sig=24)
>>>> [INFO] PJM 0083 pjsub Interactive job 5211401 completed.
>>>> Thank you
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> On 1/6/2016 12:21 PM, Satish Balay wrote:
>>>>> Do PETSc examples using VecGetArrayF90() work?
>>>>> say src/vec/vec/examples/tutorials/ex4f90.F
>>>>> Satish
>>>>> On Tue, 31 May 2016, TAY wee-beng wrote:
>>>>>> Hi,
>>>>>> I'm trying to run my MPI CFD code on Japan's K computer. My code can
>>>>>> run
>>>>>> if I
>>>>>> didn't make use of the PETSc DMDAVecGetArrayF90 subroutine. If it's
>>>>>> called
>>>>>> call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>>>>>> I get the error below. I have no problem with my code on other
>>>>>> clusters
>>>>>> using
>>>>>> the new Intel compilers. I used to have problems with DM when using
>>>>>> the
>>>>>> old
>>>>>> Intel compilers. Now on the K computer, I'm using Fujitsu's Fortran
>>>>>> compiler.
>>>>>> How can I troubleshoot?
>>>>>> Btw, I also tested on the ex13f90 example and it didn't work too. The
>>>>>> error is
>>>>>> below.
>>>>>> My code error:
>>>>>> /* size_x,size_y,size_z 76x130x136*//*
>>>>>> *//* total grid size = 1343680*//*
>>>>>> *//* recommended cores (50k / core) = 26.87360000000000*//*
>>>>>> *//* 0*//*
>>>>>> *//* 1*//*
>>>>>> *//* 1*//*
>>>>>> *//*[3]PETSC ERROR: [1]PETSC ERROR:
>>>>>> *//*[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>> Violation,
>>>>>> probably memory access out of range*//*
>>>>>> *//*[1]PETSC ERROR: Try option -start_in_debugger or
>>>>>> -on_error_attach_debugger*//*
>>>>>> *//*[1]PETSC ERROR: or see
>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind*//*
>>>>>> *//*[1]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple
>>>>>> Mac
>>>>>> OS X
>>>>>> to find memory corruption errors*//*
>>>>>> *//*[1]PETSC ERROR: likely location of problem given in stack
>>>>>> below*//*
>>>>>> *//*[1]PETSC ERROR: --------------------- Stack Frames
>>>>>> *//*[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>> available,*//*
>>>>>> *//*[1]PETSC ERROR: INSTEAD the line number of the start of the
>>>>>> function*//*
>>>>>> *//*[1]PETSC ERROR: is given.*//*
>>>>>> *//*[1]PETSC ERROR: [1] F90Array3dCreate line 244
>>>>>> /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/src/sys/f90-src/f90_cwrap.c*//*
>>>>>> *//* 1*//*
>>>>>> *//*[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>> Violation,
>>>>>> *//*[3]PETSC ERROR: Try option -start_in_debugger or
>>>>>> *//*[3]PETSC ERROR: or see
>>>>>> *//*[3]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple
>>>>>> Mac
>>>>>> OS X
>>>>>> *//*[3]PETSC ERROR: likely location of problem given in stack
>>>>>> below*//*
>>>>>> *//*[3]PETSC ERROR: --------------------- Stack Frames
>>>>>> *//*[0]PETSC ERROR:
>>>>>> *//*[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>> Violation,
>>>>>> *//*[0]PETSC ERROR: Try option -start_in_debugger or
>>>>>> *//*[0]PETSC ERROR: or see
>>>>>> *//*[0]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple
>>>>>> Mac
>>>>>> OS X
>>>>>> *//*[0]PETSC ERROR: likely location of problem given in stack
>>>>>> below*//*
>>>>>> *//*[0]PETSC ERROR: --------------------- Stack Frames
>>>>>> *//*[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>> available,*//*
>>>>>> *//*[0]PETSC ERROR: INSTEAD the line number of the start of the
>>>>>> function*//*
>>>>>> *//*[0]PETSC ERROR: is given.*//*
>>>>>> *//*[0]PETSC ERROR: [0] F90Array3dCreate line 244
>>>>>> *//*[0]PETSC ERROR: --------------------- Error Message
>>>>>> ----------------------------------------- 1*//*
>>>>>> *//*[2]PETSC ERROR:
>>>>>> *//*[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>> Violation,
>>>>>> *//*[2]PETSC ERROR: Try option -start_in_debugger or
>>>>>> *//*[2]PETSC ERROR: or see
>>>>>> *//*[2]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple
>>>>>> Mac
>>>>>> OS X
>>>>>> *//*[2]PETSC ERROR: likely location of problem given in stack
>>>>>> below*//*
>>>>>> *//*[2]PETSC ERROR: --------------------- Stack Frames
>>>>>> *//*[2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>> available,*//*
>>>>>> *//*[2]PETSC ERROR: INSTEAD the line number of the start of the
>>>>>> function*//*
>>>>>> *//*[2]PETSC ERROR: is given.*//*
>>>>>> *//*[2]PETSC ERROR: [2] F90Array3dCreate line 244
>>>>>> *//*[2]PETSC ERROR: --------------------- Error Message
>>>>>> -----------------------------------------[3]PETSC ERROR: Note: The
>>>>>> EXACT
>>>>>> line
>>>>>> numbers in the stack are not available,*//*
>>>>>> *//*[3]PETSC ERROR: INSTEAD the line number of the start of the
>>>>>> function*//*
>>>>>> *//*[3]PETSC ERROR: is given.*//*
>>>>>> *//*[3]PETSC ERROR: [3] F90Array3dCreate line 244
>>>>>> *//*[3]PETSC ERROR: --------------------- Error Message
>>>>>> *//*[3]PETSC ERROR: Signal received*//*
>>>>>> *//*[3]PETSC ERROR: See
>>>>>> for trouble shooting.*//*
>>>>>> *//*[3]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>> *//*[3]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>> by
>>>>>> Unknown Wed Jun 1 12:54:34 2016*//*
>>>>>> *//*[3]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>> --with-cxx=mpiFCC
>>>>>> -O0"
>>>>>> --LD_SHARED=
>>>>>> --with-shared----------------------*//*
>>>>>> *//*[0]PETSC ERROR: Signal received*//*
>>>>>> *//*[0]PETSC ERROR: See
>>>>>> *//*[0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>> *//*[0]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>> by
>>>>>> *//*[0]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>> --with-cxx=mpiFCC
>>>>>> -O0"
>>>>>> --LD_SHARED=
>>>>>> --with-hypre=1
>>>>>> --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4*//*
>>>>>> *//*[0]PETSC ERROR: #1 User provided function() line 0 in unknown
>>>>>> file*//*
>>>>>> *//*[m---------------------*//*
>>>>>> *//*[2]PETSC ERROR: Signal received*//*
>>>>>> *//*[2]PETSC ERROR: See
>>>>>> *//*[2]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>> *//*[2]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>> by
>>>>>> *//*[2]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>> --with-cxx=mpiFCC
>>>>>> -O0"
>>>>>> --LD_SHARED=
>>>>>> --with-hypre=1
>>>>>> *//*[2]PETSC ERROR: #1 User provided function() line 0 in unknown
>>>>>> file*//*
>>>>>> *//*[m[1]PETSC ERROR: --------------------- Error Message
>>>>>> *//*[1]PETSC ERROR: Signal received*//*
>>>>>> *//*[1]PETSC ERROR: See
>>>>>> *//*[1]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>>>> *//*[1]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036
>>>>>> by
>>>>>> *//*[1]PETSC ERROR: Configure options --with-cc=mpifcc
>>>>>> --with-cxx=mpiFCC
>>>>>> -O0"
>>>>>> --LD_SHARED=
>>>>>> --with-hypre=1
>>>>>> *//*[1]PETSC ERROR: #1 User provided function() line 0 ilibraries=0
>>>>>> --with-blas-lapack-lib=-SSL2 --with-scalapack-lib=-SCALAPACK
>>>>>> --with-hypre=1
>>>>>> *//*[3]PETSC ERROR: #1 User provided function() line 0 in unknown
>>>>>> file*//*
>>>>>> *//*[mpi::mpi-api::mpi-abort]*//*
>>>>>> *//*MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD*//*
>>>>>> *//*with errorcode 59.*//*
>>>>>> *//*NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>>>>> processes.*//*
>>>>>> *//*You may or may not see output from other processes, depending
>>>>>> on*//*
>>>>>> *//*exactly when Open MPI kills them.*//*
>>>>>> *//*[b04-036:28416]
>>>>>> [0xffffffff11360404]*//*
>>>>>> *//*[b04-036:28416]
>>>>>> [0xffffffff1110391c]*//*
>>>>>> *//*[b04-036:28416]
>>>>>> /opt/FJSVtclang/GM-1.2.0-2pi::mpi-api::mpi-abort]*//*
>>>>>> *//*MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD*//*
>>>>>> ex13f90 error:
>>>>>> /*[t00196 at b04-036 tutorials]$ mpiexec -np 2 ./ex13f90*//*
>>>>>> *//*jwe1050i-w The hardware barrier couldn't be used and continues
>>>>>> processing
>>>>>> using the software barrier.*//*
>>>>>> *//*taken to (standard) corrective action, execution continuing.*//*
>>>>>> processing
>>>>>> *//* Hi! We're solving van der Pol using 2 processes.*//*
>>>>>> *//* t x1 x2*//*
>>>>>> *//*[1]PETSC ERROR:
>>>>>> *//*[1]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly
>>>>>> illegal
>>>>>> memory access*//*
>>>>>> *//*[0]PETSC ERROR:
>>>>>> *//*[0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly
>>>>>> illegal
>>>>>> memory access*//*
>>>>>> Mac
>>>>>> OS X
>>>>>> Mac
>>>>>> OS X
>>>>>> below*//*
>>>>>> available,*//*
>>>>>> function*//*
>>>>>> *//*[1]PETSC ERROR: [1] F90Array4dCreate line 337
>>>>>> below*//*
>>>>>> available,*//*
>>>>>> function*//*
>>>>>> *//*[0]PETSC ERROR: [0] F90Array4dCreate line 337
>>>>>> *//*[1]PETSC ERROR: --------------------- Error Message
>>>>>> *//*[1]PETSC ERROR: ./ex13f90 on a petsc-3.6.3_debug named b04-036 by
>>>>>> Unknown
>>>>>> Wed Jun 1 13:04:34 2016*//*
>>>>>> --with-cxx=mpiFCC
>>>>>> -O0"
>>>>>> --LD_SHARED=
>>>>>> --with-hypre=1
>>>>>> --with-hyp*//*
