[petsc-users] Benchmarking
Vijay Gopal Chilkuri
vijay.gopal.c at gmail.com
Wed Dec 28 10:01:40 CST 2016
Dear Jed,
I will try to answer your questions. I've started a calculation with the
-eps_view and -log_view and send you the output once it is done.
On Wed, Dec 28, 2016 at 4:42 PM, Jed Brown <jed at jedbrown.org> wrote:
> Vijay Gopal Chilkuri <vijay.gopal.c at gmail.com> writes:
> How sparse is your matrix, where does it come from (affects spectrum and
> thus convergence rate),
The matrix is a variant of the Double Exchange model Hamiltonian. It has at
most 48 non-zero elements per row.
> how many eigenvalues did you request, and what
> preconditioner did you use?
I requested for 2 eigenvalues. I used the krylovshur solver from the SLEPc
package with the default preconditioner.
I'm curious about the preconditioner thing. Can you suggest some suitable
for my system ?
Thanks a lot !
Vijay
> Sending the output of running with
> -eps_view -log_view is necessary to start understanding the performance.
> > I have two questions:
> > 1. Is this time reasonable, if not, is it possible to optimize further ?
> > 2. I've tried a quick google search but could not find a comprehensive
> > benchmarking of the SLEPc library for sparse matrix diagonalization.
> Could
> > you point me to a publication/resource which has such a benchmarking ?
> > Thanks for your help.
> > PETSc Version: master branch commit: b33322e
> > SLEPc Version: master branch commit: c596d1c
> > Best,
> > Vijay
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161228/b464ddba/attachment-0001.html>
