[petsc-users] Example for unstructured grid, metis, petsc
Mohammad Mirzadeh mirzadeh at gmail.com
Mon Aug 22 09:19:05 CDT 2016
Matt,
> Yes. It is working on SNES ex12, ex62, and TS ex11. We have some more work
> to do testing adaptivity, but simple
> gradient indicators are working right I think.
>   Thanks,
>      Matt
Is there a document/todo-list sort of thing that outlines the roadmap with
p4est integration? What things are done/remains to do sort of draft?
Best,
Mohammad
>> Giang
>> On Mon, Aug 22, 2016 at 12:45 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Aug 22, 2016 at 4:05 AM, Praveen C <cpraveen at gmail.com> wrote:
>>>> Dear all
>>>> We are developing a 3d unstructured grid finite volume code for
>>>> compressible turbulent flows.
>>>> Our approach is to use metis/parmetis to partition the mesh.
>>>> Then read these partitioned mesh files in the MPI-based cfd code for
>>>> computation.
>>>> Are there any examples available in PETSc which are similar to this.
>>> That is a pretty difficult problem. The closest example we have is
>>> probably TS ex11, which can solve
>>> things like the shallow water equation and Euler. Currently it reads in
>>> a mesh, partitions in memory,
>>> and distributes the mesh using MPI. After that it can regularly refine.
>>> In the next release, we will
>>> introduce the ability to
>>>   - read a mesh in parallel
>>>   - adaptively refine in parallel using the Pragmatic package
>>>   - load balance after adaptive refinement
>>>   - use adaptive quadtree meshes from p4est
>>>   Thanks,
>>>      Matt
>>>> Thanks
>>>> praveen
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160822/25b7d0bd/attachment.html>
