[petsc-users] Example for unstructured grid, metis, petsc
Matthew Knepley
knepley at gmail.com
Mon Aug 22 08:10:59 CDT 2016
On Mon, Aug 22, 2016 at 8:02 AM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote:
> Dear Matt
> The last option is in fact very interesting. Do you know if we can already
> use it a priori from the master branch?
Yes. It is working on SNES ex12, ex62, and TS ex11. We have some more work
to do testing adaptivity, but simple
gradient indicators are working right I think.
Matt
> Giang
> On Mon, Aug 22, 2016 at 12:45 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Aug 22, 2016 at 4:05 AM, Praveen C <cpraveen at gmail.com> wrote:
>>> Dear all
>>> We are developing a 3d unstructured grid finite volume code for
>>> compressible turbulent flows.
>>> Our approach is to use metis/parmetis to partition the mesh.
>>> Then read these partitioned mesh files in the MPI-based cfd code for
>>> computation.
>>> Are there any examples available in PETSc which are similar to this.
>> That is a pretty difficult problem. The closest example we have is
>> probably TS ex11, which can solve
>> things like the shallow water equation and Euler. Currently it reads in a
>> mesh, partitions in memory,
>> and distributes the mesh using MPI. After that it can regularly refine.
>> In the next release, we will
>> introduce the ability to
>> - read a mesh in parallel
>> - adaptively refine in parallel using the Pragmatic package
>> - load balance after adaptive refinement
>> - use adaptive quadtree meshes from p4est
>> Thanks,
>> Matt
>>> Thanks
>>> praveen
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160822/a266ca71/attachment-0001.html>
