[petsc-users] Example for unstructured grid, metis, petsc
Hoang Giang Bui
hgbk2008 at gmail.com
Mon Aug 22 08:02:37 CDT 2016
Dear Matt
The last option is in fact very interesting. Do you know if we can already
use it a priori from the master branch?
Giang
On Mon, Aug 22, 2016 at 12:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 22, 2016 at 4:05 AM, Praveen C <cpraveen at gmail.com> wrote:
>> Dear all
>> We are developing a 3d unstructured grid finite volume code for
>> compressible turbulent flows.
>> Our approach is to use metis/parmetis to partition the mesh.
>> Then read these partitioned mesh files in the MPI-based cfd code for
>> computation.
>> Are there any examples available in PETSc which are similar to this.
> That is a pretty difficult problem. The closest example we have is
> probably TS ex11, which can solve
> things like the shallow water equation and Euler. Currently it reads in a
> mesh, partitions in memory,
> and distributes the mesh using MPI. After that it can regularly refine. In
> the next release, we will
> introduce the ability to
> - read a mesh in parallel
> - adaptively refine in parallel using the Pragmatic package
> - load balance after adaptive refinement
> - use adaptive quadtree meshes from p4est
> Thanks,
> Matt
>> Thanks
>> praveen
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160822/84fa5c7c/attachment.html>
