[petsc-users] Example for unstructured grid, metis, petsc
Mon Aug 22 05:45:32 CDT 2016
On Mon, Aug 22, 2016 at 4:05 AM, Praveen C <cpraveen at gmail.com> wrote:
> Dear all
> We are developing a 3d unstructured grid finite volume code for
> compressible turbulent flows.
> Our approach is to use metis/parmetis to partition the mesh.
> Then read these partitioned mesh files in the MPI-based cfd code for
> computation.
> Are there any examples available in PETSc which are similar to this.
That is a pretty difficult problem. The closest example we have is probably
TS ex11, which can solve
things like the shallow water equation and Euler. Currently it reads in a
mesh, partitions in memory,
and distributes the mesh using MPI. After that it can regularly refine. In
the next release, we will
introduce the ability to
  - read a mesh in parallel
  - adaptively refine in parallel using the Pragmatic package
  - load balance after adaptive refinement
  - use adaptive quadtree meshes from p4est
     Matt
> Thanks
> praveen
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160822/d1ccea38/attachment.html>
