[petsc-users] High order finite volume method in unstructured grid using PETSc
Matthew Knepley
knepley at gmail.com
Thu Aug 11 10:32:00 CDT 2016
On Thu, Aug 11, 2016 at 8:16 AM, leejearl <leejearl at 126.com> wrote:
> Hi, all:
> I want to build a high order finite volume method in unstructured grid
> using PETSc.
> The first issue is to partition the grid. I use the DMPlex to manage the
> data structure.
> The procedure is as follow:
> 1> DMPlexCreateFromFile(), to load a grid into DMPlex;
> 2> DMPlexDistribute(dm, overlap, NULL, &dmdist)
> I use DMPlexDistribute to distribute gird. For a high order method, I want
> to set the
> value of overlap to 2, and I think 0 or 1 is not enough. So, I test the
> example
> "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c". The example is a 2ND
> order FVM
> code, and it use "DMPlexDistribute" too. But when I use the command
> "mpirun -n 3 ./ex11 -ufv_mesh_overlap 2" to set the value of overlap to 2,
> it suffers
> an error.
> Is there anyone can help me to point out:
> 1> Can I set the value of overlap to 2?
> 2> If I want to give the value of overlap as 2, is there any additional
> codes which must be
> added?
> Any helps are appreciated.
I replied to this in the other mail.
Matt
> leejearl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160811/9c3303da/attachment-0001.html>
