[petsc-users] Meaning of Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
Athena Paz
athena.paz1 at gmail.com
Tue Aug 9 02:24:45 CDT 2016
Hi all,
I'm very new to PETSC. I'm trying to solve a diffusion problem in 3D. I
tried running a 500 x 500 x 500 grid using 20 processors but I encounter
the following error:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#
valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR:
valgrind
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] MatSetValues_SeqAIJ line 441
/home/paz/petsc-3.7.3/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: [0] MatSetValues line 1157
/home/paz/petsc-3.7.3/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] MatSetValuesLocal line 2019
[0]PETSC ERROR: [0] DMCreateMatrix_DA_3d_MPIAIJ line 1036
/home/paz/petsc-3.7.3/src/dm/impls/da/fdda.c
[0]PETSC ERROR: [0] DMCreateMatrix_DA line 625
[0]PETSC ERROR: [0] DMCreateMatrix line 1171
/home/paz/petsc-3.7.3/src/dm/interface/dm.c
[0]PETSC ERROR: [0] SNESSetUpMatrices line 579
/home/paz/petsc-3.7.3/src/snes/interface/snes.c
[0]PETSC ERROR: [0] SNESSetUp_NEWTONLS line 303
/home/paz/petsc-3.7.3/src/snes/impls/ls/ls.c
[0]PETSC ERROR: [0] SNESSetUp line 2661
[0]PETSC ERROR: [0] SNESSolve line 3958
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
[0]PETSC ERROR: ./ex7 on a arch-linux2-c-debug named akagi by paz Tue Aug
9 16:01:17 2016
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-fblaslapack --download-mpich --with-debugging
[0]PETSC ERROR: #1 User provided function() line 0 in unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: aborting job:
What does this mean? I am able to run the code successfully with a
300x300x300 grid size. I also tried using -malloc_debug and valgrind as
suggested in the Debugging FAQ for a small grid size and the code comes out
clean. Any help is much appreciated!
Thank you all for your time! Have a great day!
Athena
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160809/b837d7d7/attachment.html>
