[petsc-users] Meaning of Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
Karl Rupp
rupp at iue.tuwien.ac.at
Tue Aug 9 03:06:18 CDT 2016
are you running the code on a cluster? If so, you need to submit your
jobs through the batch system, as larger jobs get killed by the batch
system.
Best regards,
Karli
On 08/09/2016 09:24 AM, Athena Paz wrote:
> Hi all,
> I'm very new to PETSC. I'm trying to solve a diffusion problem in 3D. I
> tried running a 500 x 500 x 500 grid using 20 processors but I encounter
> the following error:
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [0]PETSC ERROR:
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] MatSetValues_SeqAIJ line 441
> /home/paz/petsc-3.7.3/src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: [0] MatSetValues line 1157
> /home/paz/petsc-3.7.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] MatSetValuesLocal line 2019
> [0]PETSC ERROR: [0] DMCreateMatrix_DA_3d_MPIAIJ line 1036
> /home/paz/petsc-3.7.3/src/dm/impls/da/fdda.c
> [0]PETSC ERROR: [0] DMCreateMatrix_DA line 625
> [0]PETSC ERROR: [0] DMCreateMatrix line 1171
> /home/paz/petsc-3.7.3/src/dm/interface/dm.c
> [0]PETSC ERROR: [0] SNESSetUpMatrices line 579
> /home/paz/petsc-3.7.3/src/snes/interface/snes.c
> [0]PETSC ERROR: [0] SNESSetUp_NEWTONLS line 303
> /home/paz/petsc-3.7.3/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: [0] SNESSetUp line 2661
> [0]PETSC ERROR: [0] SNESSolve line 3958
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
> [0]PETSC ERROR: ./ex7 on a arch-linux2-c-debug named akagi by paz Tue
> Aug 9 16:01:17 2016
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich --with-debugging
> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [unset]: aborting job:
> What does this mean? I am able to run the code successfully with a
> 300x300x300 grid size. I also tried using -malloc_debug and valgrind as
> suggested in the Debugging FAQ for a small grid size and the code comes
> out clean. Any help is much appreciated!
> Thank you all for your time! Have a great day!
> Athena
