[petsc-users] Hypre's BoomerAMG vs PETSc's GAMG?
Justin Chang jychang48 at gmail.com
Thu Sep 24 20:21:06 CDT 2015
Hi all,
I ran both BoomerAMG and GAMG. It seems to me there is a lot more "info" in
GAMG's log_summary than the one for Hypre's BoomerAMG. Is the latter
completely documented within PETSc's log_summary? Because I am not sure
these performance metrics make sense to me.
Attached are the -log_summary and -info outputs for the respective solvers.
Justin
On Mon, Sep 21, 2015 at 1:25 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Okay I will just experiment around with these then. Thanks for the input
> everyone
> On Mon, Sep 21, 2015 at 6:21 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> And I will just add that performance is sensitive to parameters. The
>> defaults try to be conservative and hypre's seem to be geared for 2D low
>> order discretizations.  GAMG is probably a bit more geared for 3D.  If you
>> are interested in looking this carefully you can run GAMG with '-info', and
>> grep on GAMG, and send us the results and we can verify that it running OK.
>> Also run with -log_summary and send that separately.  The two solvers
>> should be about the same speed on your problem.
>> On Fri, Sep 18, 2015 at 7:36 AM, Jed Brown <jed at jedbrown.org> wrote:
>>> Justin Chang <jychang48 at gmail.com> writes:
>>> > I see that there's GAMG and there's Hypre's BoomerAMG (and perhaps
>>> others
>>> > too?)
>>> ML
>>> > What exactly is the difference between these two? Do they have very
>>> > different implementations under the hood? Does one have better
>>> > scalability over another? Or more importantly, when would I choose one
>>> > over the other?
>>> BoomerAMG is classical AMG, which is a different coarsening strategy
>>> From GAMG and ML which use smoothed aggregation.  The math is different
>>> and the implementation is different.  ML and GAMG have similar math and
>>> there exist configurations that are equivalent.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150924/4982f8bd/attachment-0001.html>
[0] PetscInitialize(): PETSc successfully started: number of processors = 1
[0] PetscInitialize(): Running on machine: Justins-MacBook-Pro.local
[0] PetscCommDuplicate(): Duplicating a communicator 4561956480 140344159520272 max tags = 2147483647
[0] PetscCommDuplicate(): Using internal PETSc communicator 4561956480 140344159520272
[0] PetscCommDuplicate(): Duplicating a communicator 4561957504 140344119264720 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140344119264720
[0] Petsc_DelComm_Outer(): User MPI_Comm 4561957504 is being freed after removing reference from inner PETSc comm to this outer comm
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140344119264720
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140344119264720
[0] PetscCommDuplicate(): Duplicating a communicator 4561957504 140344158987552 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140344158987552
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140344158987552
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140344158987552
[0] PetscCommDuplicate(): Duplicating a communicator 4561957504 140344159036880 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140344159036880
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140344159036880
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140344159036880
[0] PetscCommDuplicate(): Duplicating a communicator 4561957504 140344159525648 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140344159525648
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140344159525648
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140344159525648
[0] PetscCommDuplicate(): Duplicating a communicator 4561957504 140344159526976 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140344159526976
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140344159526976
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140344159526976
[0] VecScatterCreate(): Special case: sequential vector stride to stride
[0] PetscCommDuplicate(): Duplicating a communicator 4561957504 140344162264384 max tags = 2147483647
[0] PetscCommDuplicate(): Using internal PETSc communicator 4561957504 140344162264384
[0] MatSetOption_SeqAIJ(): Option NEW_NONZERO_LOCATIONS ignored
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 10302; storage space: 0 unneeded,181804 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 18
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 10302) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 10302 nodes out of 10302 rows. Not using Inode routines
	Time = 100.000000
[0] PCSetUp(): Setting up PC for first time
[0] PCSetUp_GAMG(): level 0) N=10302, n data rows=1, n data cols=1, nnz/row (ave)=18, np=1
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 10302; storage space: 91706 unneeded,90098 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 9
[0] PCGAMGFilterGraph(): 	 49.5578% nnz after filtering, with threshold 0, 17.6474 nnz ave. (N=10302)
[0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
[0] MatGetSymbolicTranspose_SeqAIJ(): Getting Symbolic Transpose.
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 10302; storage space: 0 unneeded,90098 used
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 10302; storage space: 0 unneeded,246114 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 25
[0] MatMatMultSymbolic_SeqAIJ_SeqAIJ(): Reallocs 0; Fill ratio: given 2 needed 1.36582.
[0] MatMatMultSymbolic_SeqAIJ_SeqAIJ(): Use MatMatMult(A,B,MatReuse,1.36582,&C) for best performance.;
[0] MatRestoreSymbolicTranspose_SeqAIJ(): Restoring Symbolic Transpose.
[0] maxIndSetAgg(): 	 removed 102 of 10302 vertices.  801 selected.
[0] PCGAMGProlongator_AGG(): New grid 801 nodes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 801; storage space: 102 unneeded,10200 used
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 102)/(num_localrows 10302) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 3342 nodes of 10302. Limit used: 5. Using Inode routines
[0] KSPSetNormType(): Warning: setting KSPNormType to skip computing the norm
 KSP convergence test is implicitly set to KSPConvergedSkip
[0] PCSetUp(): Leaving PC with identical preconditioner since operator is unchanged
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=2.944119e+00 min=7.255192e-02 PC=jacobi
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 801; storage space: 0 unneeded,50460 used
[0] MatSeqAIJCheckInode(): Found 9108 nodes out of 10302 rows. Not using Inode routines
[0] MatMatMultSymbolic_SeqAIJ_SeqAIJ(): Use MatMatMult(A,B,MatReuse,1,&C) for best performance.;
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 801 X 801; storage space: 0 unneeded,17709 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 33
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 801) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 801 nodes out of 801 rows. Not using Inode routines
[0] MatPtAPSymbolic_SeqAIJ_SeqAIJ_SparseAxpy(): Reallocs 0; Fill ratio: given 2 needed 1.
[0] MatPtAPSymbolic_SeqAIJ_SeqAIJ_SparseAxpy(): Use MatPtAP(A,P,MatReuse,1,&C) for best performance.
[0] PCSetUp_GAMG(): 1) N=801, n data cols=1, nnz/row (ave)=22, 1 active pes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 801 X 801; storage space: 9106 unneeded,8603 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 17
[0] PCGAMGFilterGraph(): 	 48.5798% nnz after filtering, with threshold 0, 22.1086 nnz ave. (N=801)
[0] maxIndSetAgg(): 	 removed 0 of 801 vertices.  138 selected.
[0] PCGAMGProlongator_AGG(): New grid 138 nodes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 801 X 138; storage space: 0 unneeded,801 used
[0] MatSeqAIJCheckInode(): Found 601 nodes of 801. Limit used: 5. Using Inode routines
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.910989e+00 min=5.766908e-02 PC=jacobi
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 801 X 138; storage space: 0 unneeded,6120 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
[0] MatSeqAIJCheckInode(): Found 787 nodes out of 801 rows. Not using Inode routines
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 138 X 138; storage space: 0 unneeded,5350 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 66
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 138) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 137 nodes out of 138 rows. Not using Inode routines
[0] PCSetUp_GAMG(): 2) N=138, n data cols=1, nnz/row (ave)=38, 1 active pes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 138 X 138; storage space: 2918 unneeded,2432 used
[0] PCGAMGFilterGraph(): 	 45.4579% nnz after filtering, with threshold 0, 38.7681 nnz ave. (N=138)
[0] maxIndSetAgg(): 	 removed 0 of 138 vertices.  20 selected.
[0] PCGAMGProlongator_AGG(): New grid 20 nodes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 138 X 20; storage space: 0 unneeded,138 used
[0] MatSeqAIJCheckInode(): Found 79 nodes of 138. Limit used: 5. Using Inode routines
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.601213e+00 min=2.765731e-02 PC=jacobi
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 138 X 20; storage space: 0 unneeded,1074 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
[0] MatSeqAIJCheckInode(): Found 125 nodes out of 138 rows. Not using Inode routines
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 20 X 20; storage space: 0 unneeded,388 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 20
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 20) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 10 nodes of 20. Limit used: 5. Using Inode routines
[0] PCSetUp_GAMG(): 3) N=20, n data cols=1, nnz/row (ave)=19, 1 active pes
[0] PCSetUp_GAMG(): 4 levels, grid complexity = 1.12897
[0] PCSetUp_MG(): Using outer operators to define finest grid operator
  because PCMGGetSmoother(pc,nlevels-1,&ksp);KSPSetOperators(ksp,...); was not called.
[0] MatLUFactorSymbolic_SeqAIJ(): Reallocs 0 Fill ratio:given 5 needed 1
[0] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 1 or use
[0] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,1);
[0] MatLUFactorSymbolic_SeqAIJ(): for best performance.
[0] MatSeqAIJCheckInode_FactorLU(): Found 10 nodes of 20. Limit used: 5. Using Inode routines
[0] KSPConvergedDefault(): Linear solver has converged. Residual norm 3.809939815562e-06 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 4.066392182486e+01 at iteration 50
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 10302; storage space: 94882 unneeded,86922 used
[0] PCGAMGFilterGraph(): 	 47.8108% nnz after filtering, with threshold 0, 17.6474 nnz ave. (N=10302)
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 10302; storage space: 0 unneeded,86922 used
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 10302; storage space: 0 unneeded,236634 used
[0] MatMatMultSymbolic_SeqAIJ_SeqAIJ(): Reallocs 0; Fill ratio: given 2 needed 1.3612.
[0] MatMatMultSymbolic_SeqAIJ_SeqAIJ(): Use MatMatMult(A,B,MatReuse,1.3612,&C) for best performance.;
[0] maxIndSetAgg(): 	 removed 502 of 10302 vertices.  773 selected.
[0] PCGAMGProlongator_AGG(): New grid 773 nodes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 773; storage space: 502 unneeded,9800 used
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 502)/(num_localrows 10302) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 3808 nodes of 10302. Limit used: 5. Using Inode routines
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=2.917222e+00 min=6.952647e-02 PC=jacobi
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10302 X 773; storage space: 0 unneeded,49752 used
[0] MatSeqAIJCheckInode(): Found 8838 nodes out of 10302 rows. Not using Inode routines
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 773 X 773; storage space: 0 unneeded,17051 used
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 773) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 773 nodes out of 773 rows. Not using Inode routines
[0] PCSetUp_GAMG(): 1) N=773, n data cols=1, nnz/row (ave)=22, 1 active pes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 773 X 773; storage space: 8762 unneeded,8289 used
[0] PCGAMGFilterGraph(): 	 48.613% nnz after filtering, with threshold 0, 22.0582 nnz ave. (N=773)
[0] maxIndSetAgg(): 	 removed 0 of 773 vertices.  142 selected.
[0] PCGAMGProlongator_AGG(): New grid 142 nodes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 773 X 142; storage space: 0 unneeded,773 used
[0] MatSeqAIJCheckInode(): Found 580 nodes of 773. Limit used: 5. Using Inode routines
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.935373e+00 min=5.212847e-02 PC=jacobi
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 773 X 142; storage space: 0 unneeded,5912 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 14
[0] MatSeqAIJCheckInode(): Found 766 nodes out of 773 rows. Not using Inode routines
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 142 X 142; storage space: 0 unneeded,5436 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 65
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 142) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 142 nodes out of 142 rows. Not using Inode routines
[0] PCSetUp_GAMG(): 2) N=142, n data cols=1, nnz/row (ave)=38, 1 active pes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 142 X 142; storage space: 2946 unneeded,2490 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 31
[0] PCGAMGFilterGraph(): 	 45.8057% nnz after filtering, with threshold 0, 38.2817 nnz ave. (N=142)
[0] maxIndSetAgg(): 	 removed 0 of 142 vertices.  13 selected.
[0] PCGAMGProlongator_AGG(): New grid 13 nodes
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 142 X 13; storage space: 0 unneeded,142 used
[0] MatSeqAIJCheckInode(): Found 86 nodes of 142. Limit used: 5. Using Inode routines
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.625439e+00 min=2.992143e-02 PC=jacobi
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 142 X 13; storage space: 0 unneeded,885 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 10
[0] MatSeqAIJCheckInode(): Found 123 nodes out of 142 rows. Not using Inode routines
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 13 X 13; storage space: 0 unneeded,169 used
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 13) < 0.6. Do not use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 3 nodes of 13. Limit used: 5. Using Inode routines
[0] PCSetUp_GAMG(): 3) N=13, n data cols=1, nnz/row (ave)=13, 1 active pes
[0] PCSetUp_GAMG(): 4 levels, grid complexity = 1.12462
[0] MatSeqAIJCheckInode_FactorLU(): Found 3 nodes of 13. Limit used: 5. Using Inode routines
[0] KSPConvergedDefault(): Linear solver has converged. Residual norm 3.083449067853e-06 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 3.534731080542e+01 at iteration 37
	Wall-clock time: 1.018e+00 seconds
[0] PetscFinalize(): PetscFinalize() called
	Time = 100.000000
	Wall-clock time: 1.042e+00 seconds
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
2D_plume_ADR_ex1.py on a arch-python-macosx-10.10-x86_64 named Justins-MacBook-Pro.local with 1 processor, by justin Thu Sep 24 19:07:45 2015
Using Petsc Development GIT revision: v3.5.2-4224-gf2b0407  GIT Date: 2015-08-27 23:56:02 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           1.948e+00      1.00000   1.948e+00
Objects:              5.680e+02      1.00000   5.680e+02
Flops:                7.381e+08      1.00000   7.381e+08  7.381e+08
Flops/sec:            3.788e+08      1.00000   3.788e+08  3.788e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.1395e+00  58.5%  7.4010e+07  10.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:       Advection: 4.3978e-01  22.6%  3.4758e+08  47.1%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:       Diffusion: 3.6915e-01  18.9%  3.1646e+08  42.9%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecSet                11 1.0 3.1638e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin       11 1.0 5.2452e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin      12 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        12 1.0 7.2503e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           1 1.0 1.0208e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
DMPlexStratify         2 1.0 3.1607e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph             7 1.0 4.3464e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 1: Advection
VecMDot               60 1.0 5.3263e-04 1.0 2.47e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  4642
VecTDot              100 1.0 4.9376e-04 1.0 2.06e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  4173
VecNorm              117 1.0 3.2520e-04 1.0 1.55e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4752
VecScale              66 1.0 7.4863e-05 1.0 2.47e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3303
VecCopy              161 1.0 4.1890e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               619 1.0 2.2171e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY              106 1.0 7.0024e-04 1.0 2.11e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  3007
VecAYPX             1273 1.0 3.8307e-03 1.0 6.74e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  2  0  0  0  1760
VecAXPBYCZ           612 1.0 2.4939e-03 1.0 1.15e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  3  0  0  0  4598
VecMAXPY              66 1.0 5.5337e-04 1.0 2.92e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  5282
VecAssemblyBegin       3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      33 1.0 1.4234e-04 1.0 1.24e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   869
VecScatterBegin        6 1.0 3.8147e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          66 1.0 1.7452e-04 1.0 7.42e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4251
MatMult             1028 1.0 7.6496e-02 1.0 1.48e+08 1.0 0.0e+00 0.0e+00 0.0e+00  4 20  0  0  0  17 42  0  0  0  1929
MatMultAdd           153 1.0 7.4027e-03 1.0 5.88e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   2  2  0  0  0   794
MatMultTranspose     153 1.0 7.9162e-03 1.0 5.88e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   2  2  0  0  0   743
MatSolve              51 1.0 1.5569e-04 1.0 3.86e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   248
MatSOR               951 1.0 1.0649e-01 1.0 1.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00  5 18  0  0  0  24 37  0  0  0  1220
MatLUFactorSym         1 1.0 2.1935e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 4.7922e-05 1.0 2.14e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    45
MatConvert             3 1.0 1.6639e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               9 1.0 4.6420e-04 1.0 5.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1131
MatResidual          153 1.0 1.0476e-02 1.0 2.09e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   2  6  0  0  0  1995
MatAssemblyBegin      24 1.0 4.0531e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        24 1.0 2.0115e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow          44964 1.0 3.9079e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            1 1.0 6.9141e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 3.0994e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             3 1.0 5.0902e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                3 1.0 2.3091e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMatMult             3 1.0 4.0581e-03 1.0 4.65e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0   115
MatMatMultSym          3 1.0 2.8350e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMatMultNum          3 1.0 1.2052e-03 1.0 4.65e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   386
MatPtAP                3 1.0 1.8055e-02 1.0 3.33e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  1  0  0  0   184
MatPtAPSymbolic        3 1.0 5.2621e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatPtAPNumeric         3 1.0 1.2783e-02 1.0 3.33e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  1  0  0  0   260
MatTrnMatMult          1 1.0 7.5231e-03 1.0 1.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0   212
MatTrnMatMultSym       1 1.0 5.3370e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatTrnMatMultNum       1 1.0 2.1839e-03 1.0 1.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   732
MatGetSymTrans         4 1.0 6.4635e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGGraph_AGG        3 1.0 1.1266e-02 1.0 4.10e+05 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0    36
PCGAMGCoarse_AGG       3 1.0 8.6429e-03 1.0 1.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0   185
PCGAMGProl_AGG         3 1.0 1.3149e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGPOpt_AGG         3 1.0 1.5178e-02 1.0 7.78e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   3  2  0  0  0   513
GAMG: createProl       3 1.0 3.6541e-02 1.0 9.79e+06 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   8  3  0  0  0   268
  Graph                6 1.0 1.1213e-02 1.0 4.10e+05 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0    37
  MIS/Agg              3 1.0 5.4193e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: col data         3 1.0 2.5749e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: frmProl0         3 1.0 1.2050e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: smooth           3 1.0 1.5178e-02 1.0 7.78e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   3  2  0  0  0   513
GAMG: partLevel        3 1.0 1.8073e-02 1.0 3.33e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  1  0  0  0   184
PCSetUp                2 1.0 5.5268e-02 1.0 1.31e+07 1.0 0.0e+00 0.0e+00 0.0e+00  3  2  0  0  0  13  4  0  0  0   237
PCSetUpOnBlocks       51 1.0 1.4710e-04 1.0 2.14e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    15
PCApply               51 1.0 2.0163e-01 1.0 2.88e+08 1.0 0.0e+00 0.0e+00 0.0e+00 10 39  0  0  0  46 83  0  0  0  1428
KSPGMRESOrthog        60 1.0 1.0383e-03 1.0 4.95e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  4763
KSPSetUp              12 1.0 7.9489e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 2.6766e-01 1.0 3.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00 14 44  0  0  0  61 93  0  0  0  1214
--- Event Stage 2: Diffusion
VecMDot               60 1.0 6.3133e-04 1.0 2.47e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  3908
VecTDot               74 1.0 3.8075e-04 1.0 1.52e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4004
VecNorm              104 1.0 2.5749e-04 1.0 1.28e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4957
VecScale              66 1.0 7.4387e-05 1.0 2.47e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3317
VecCopy              122 1.0 3.3307e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               501 1.0 1.9374e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY               80 1.0 5.5432e-04 1.0 1.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2831
VecAYPX              948 1.0 3.0065e-03 1.0 5.00e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  2  0  0  0  1664
VecAXPBYCZ           456 1.0 1.7724e-03 1.0 8.52e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  3  0  0  0  4810
VecMAXPY              66 1.0 6.7997e-04 1.0 2.92e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  4289
VecAssemblyEnd         3 1.0 9.5367e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      33 1.0 1.2732e-04 1.0 1.23e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   969
VecScatterBegin        6 1.0 3.2902e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          66 1.0 1.6809e-04 1.0 7.40e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4404
MatMult              781 1.0 5.9309e-02 1.0 1.12e+08 1.0 0.0e+00 0.0e+00 0.0e+00  3 15  0  0  0  16 35  0  0  0  1882
MatMultAdd           114 1.0 5.7106e-03 1.0 4.30e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   2  1  0  0  0   753
MatMultTranspose     114 1.0 6.1491e-03 1.0 4.30e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   2  1  0  0  0   699
MatSolve              38 1.0 7.7963e-05 1.0 1.24e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   158
MatSOR               717 1.0 8.3516e-02 1.0 9.77e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4 13  0  0  0  23 31  0  0  0  1169
MatLUFactorSym         1 1.0 1.1921e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 5.9605e-06 1.0 9.39e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   158
MatConvert             3 1.0 3.9697e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               9 1.0 4.9543e-04 1.0 5.22e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1053
MatResidual          114 1.0 8.5526e-03 1.0 1.55e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   2  5  0  0  0  1815
MatAssemblyBegin      24 1.0 4.7684e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        24 1.0 2.0373e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRow          44868 1.0 3.2351e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            1 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 2.2888e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             3 1.0 6.3801e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                3 1.0 2.1653e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMatMult             3 1.0 3.7990e-03 1.0 4.53e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0   119
MatMatMultSym          3 1.0 2.4741e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMatMultNum          3 1.0 1.3139e-03 1.0 4.53e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   345
MatPtAP                3 1.0 1.8103e-02 1.0 3.24e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   5  1  0  0  0   179
MatPtAPSymbolic        3 1.0 5.9602e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatPtAPNumeric         3 1.0 1.2134e-02 1.0 3.24e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  1  0  0  0   267
MatTrnMatMult          1 1.0 1.0095e-02 1.0 1.54e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0   152
MatTrnMatMultSym       1 1.0 7.6640e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatTrnMatMultNum       1 1.0 2.4290e-03 1.0 1.54e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0   632
MatGetSymTrans         4 1.0 6.4111e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGGraph_AGG        3 1.0 8.3809e-03 1.0 4.09e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0    49
PCGAMGCoarse_AGG       3 1.0 1.1429e-02 1.0 1.54e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0   134
PCGAMGProl_AGG         3 1.0 1.4434e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGPOpt_AGG         3 1.0 1.2587e-02 1.0 7.75e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   3  2  0  0  0   616
GAMG: createProl       3 1.0 3.3962e-02 1.0 9.69e+06 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   9  3  0  0  0   285
  Graph                6 1.0 8.3411e-03 1.0 4.09e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0    49
  MIS/Agg              3 1.0 6.6781e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: col data         3 1.0 2.9087e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: frmProl0         3 1.0 1.3227e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: smooth           3 1.0 1.2586e-02 1.0 7.75e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   3  2  0  0  0   616
GAMG: partLevel        3 1.0 1.8109e-02 1.0 3.24e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   5  1  0  0  0   179
PCSetUp                2 1.0 5.2608e-02 1.0 1.29e+07 1.0 0.0e+00 0.0e+00 0.0e+00  3  2  0  0  0  14  4  0  0  0   246
PCSetUpOnBlocks       38 1.0 7.8678e-05 1.0 9.39e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    12
PCApply               38 1.0 1.5786e-01 1.0 2.17e+08 1.0 0.0e+00 0.0e+00 0.0e+00  8 29  0  0  0  43 68  0  0  0  1373
KSPGMRESOrthog        60 1.0 1.2169e-03 1.0 4.94e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0  4056
KSPSetUp              12 1.0 6.5565e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 2.1840e-01 1.0 2.47e+08 1.0 0.0e+00 0.0e+00 0.0e+00 11 34  0  0  0  59 78  0  0  0  1132
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     6              3         1704     0
              Viewer     1              0            0     0
           Index Set    34             32       351112     0
   IS L to G Mapping    13              0            0     0
             Section    21              3         1992     0
              Vector    26            162      4803960     0
      Vector Scatter     9             15         9840     0
              Matrix    10             14       186192     0
      Preconditioner     4             14        14088     0
       Krylov Solver     4             20       198208     0
                 Tao     2              2         3920     0
    Distributed Mesh     8              1         4904     0
    GraphPartitioner     2              1          604     0
Star Forest Bipartite Graph    19              6         4800     0
     Discrete System     8              1          848     0
       TaoLineSearch     2              2         1760     0
           Index Set    16             13        10168     0
              Vector   141             67      2080952     0
      Vector Scatter     4              0            0     0
              Matrix    18             11      5703204     0
      Matrix Coarsen     3              3         1884     0
      Preconditioner    11              6         5544     0
       Krylov Solver    11              3        90576     0
           Index Set    12              9         7008     0
              Vector   138             67      2076672     0
      Vector Scatter     2              0            0     0
              Matrix    18             11      5688036     0
Average time to get PetscTime(): 0
#PETSc Option Table entries:
-A_ksp_rtol 1e-7
-A_ksp_type cg
-A_pc_type gamg
-D_ksp_rtol 1e-7
-D_ksp_type cg
-D_pc_type gamg
-log_summary
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --prefix=/Users/justin/Software/firedrake/lib/python2.7/site-packages/petsc PETSC_ARCH=arch-python-macosx-10.10-x86_64 --with-shared-libraries=1 --with-debugging=0 --with-c2html=0 --with-cc=/usr/local/bin/mpicc --with-cxx=/usr/local/bin/mpicxx --with-fc=/usr/local/bin/mpif90 --download-ctetgen --download-triangle --download-chaco --download-metis --download-parmetis --download-scalapack --download-hypre=1 --download-mumps --download-netcdf --download-hdf5 --download-exodusii
Libraries compiled on Fri Sep  4 01:55:38 2015 on Justins-MacBook-Pro.local
Machine characteristics: Darwin-14.5.0-x86_64-i386-64bit
Using PETSc directory: /private/var/folders/jd/qh5zn6jn5kz_byz9gxz5kl2m0000gn/T/pip-I00cfW-build
Using PETSc arch: arch-python-macosx-10.10-x86_64
Using C compiler: /usr/local/bin/mpicc  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /usr/local/bin/mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/private/var/folders/jd/qh5zn6jn5kz_byz9gxz5kl2m0000gn/T/pip-I00cfW-build/arch-python-macosx-10.10-x86_64/include -I/private/var/folders/jd/qh5zn6jn5kz_byz9gxz5kl2m0000gn/T/pip-I00cfW-build/include -I/private/var/folders/jd/qh5zn6jn5kz_byz9gxz5kl2m0000gn/T/pip-I00cfW-build/include -I/private/var/folders/jd/qh5zn6jn5kz_byz9gxz5kl2m0000gn/T/pip-I00cfW-build/arch-python-macosx-10.10-x86_64/include -I/Users/justin/Software/firedrake/lib/python2.7/site-packages/petsc/include -I/usr/local/Cellar/open-mpi/1.10.0/include
Using C linker: /usr/local/bin/mpicc
Using Fortran linker: /usr/local/bin/mpif90
Using libraries: -Wl,-rpath,/private/var/folders/jd/qh5zn6jn5kz_byz9gxz5kl2m0000gn/T/pip-I00cfW-build/arch-python-macosx-10.10-x86_64/lib -L/private/var/folders/jd/qh5zn6jn5kz_byz9gxz5kl2m0000gn/T/pip-I00cfW-build/arch-python-macosx-10.10-x86_64/lib -lpetsc -Wl,-rpath,/Users/justin/Software/firedrake/lib/python2.7/site-packages/petsc/lib -L/Users/justin/Software/firedrake/lib/python2.7/site-packages/petsc/lib -lHYPRE -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.0/lib -L/usr/local/Cellar/open-mpi/1.10.0/lib -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.1.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.1.0/lib/darwin -lclang_rt.osx -lmpi_cxx -lc++ -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -lclang_rt.osx -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -llapack -lblas -lparmetis -lmetis -ltriangle -lchaco -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lctetgen -lssl -lcrypto -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -Wl,-rpath,/usr/local/Cellar/gcc/5.2.0/lib/gcc/5/gcc/x86_64-apple-darwin14.4.0/5.2.0 -L/usr/local/Cellar/gcc/5.2.0/lib/gcc/5/gcc/x86_64-apple-darwin14.4.0/5.2.0 -Wl,-rpath,/usr/local/Cellar/gcc/5.2.0/lib/gcc/5 -L/usr/local/Cellar/gcc/5.2.0/lib/gcc/5 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpi_cxx -lc++ -lclang_rt.osx -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.0/lib -L/usr/local/Cellar/open-mpi/1.10.0/lib -ldl -lmpi -lSystem -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -lclang_rt.osx -ldl
[0] PetscCommDuplicate(): Duplicating a communicator 4429799040 140522300059408 max tags = 2147483647
[0] PetscCommDuplicate(): Using internal PETSc communicator 4429799040 140522300059408
[0] PetscCommDuplicate(): Duplicating a communicator 4429800064 140522300073648 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140522300073648
[0] Petsc_DelComm_Outer(): User MPI_Comm 4429800064 is being freed after removing reference from inner PETSc comm to this outer comm
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140522300073648
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140522300073648
[0] PetscCommDuplicate(): Duplicating a communicator 4429800064 140522300072848 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140522300072848
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140522300072848
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140522300072848
[0] PetscCommDuplicate(): Duplicating a communicator 4429800064 140522300128496 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140522300128496
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140522300128496
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140522300128496
[0] PetscCommDuplicate(): Duplicating a communicator 4429800064 140522299392960 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140522299392960
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140522299392960
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140522299392960
[0] PetscCommDuplicate(): Duplicating a communicator 4429800064 140522299393728 max tags = 2147483647
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator embedded in a user MPI_Comm 140522299393728
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm 140522299393728
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 140522299393728
[0] PetscCommDuplicate(): Duplicating a communicator 4429800064 140522300427040 max tags = 2147483647
[0] PetscCommDuplicate(): Using internal PETSc communicator 4429800064 140522300427040
	Time = 100.000000
[0] KSPConvergedDefault(): Linear solver has converged. Residual norm 3.965904976486e-06 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 5.489878564360e+01 at iteration 48
[0] KSPConvergedDefault(): Linear solver has converged. Residual norm 3.460837870404e-06 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 4.917749887197e+01 at iteration 19
	Wall-clock time: 9.638e-01 seconds
	Time = 100.000000
	Wall-clock time: 9.561e-01 seconds
2D_plume_ADR_ex1.py on a arch-python-macosx-10.10-x86_64 named Justins-MacBook-Pro.local with 1 processor, by justin Thu Sep 24 19:08:10 2015
Time (sec):           1.763e+00      1.00000   1.763e+00
Objects:              2.060e+02      1.00000   2.060e+02
Flops:                1.978e+08      1.00000   1.978e+08  1.978e+08
Flops/sec:            1.122e+08      1.00000   1.122e+08  1.122e+08
 0:      Main Stage: 1.0402e+00  59.0%  7.4010e+07  37.4%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:       Advection: 4.4468e-01  25.2%  4.5603e+07  23.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:       Diffusion: 2.7806e-01  15.8%  7.8232e+07  39.5%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
Phase summary info:
VecSet                11 1.0 3.0589e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin       11 1.0 4.8637e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        12 1.0 7.7915e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           1 1.0 8.5580e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
DMPlexStratify         2 1.0 2.8751e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph             7 1.0 4.8900e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecTDot               96 1.0 4.2796e-04 1.0 1.98e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  4  0  0  0  4622
VecNorm               49 1.0 2.4843e-04 1.0 1.01e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0  4064
VecCopy                2 1.0 1.9073e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                57 1.0 3.8910e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               96 1.0 7.1192e-04 1.0 1.98e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  4  0  0  0  2778
VecAYPX               47 1.0 3.5429e-04 1.0 9.68e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0  2733
VecScatterBegin        6 1.0 3.0994e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               48 1.0 9.8245e-03 1.0 1.70e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  9  0  0  0   2 37  0  0  0  1726
MatConvert             1 1.0 1.3752e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 9.5367e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                1 1.0 4.5080e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0  10  0  0  0  0     0
PCApply               49 1.0 2.2821e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 13  0  0  0  0  51  0  0  0  0     0
KSPSetUp               1 1.0 1.2302e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 2.8528e-01 1.0 2.29e+07 1.0 0.0e+00 0.0e+00 0.0e+00 16 12  0  0  0  64 50  0  0  0    80
VecTDot               38 1.0 1.5736e-04 1.0 7.83e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  4975
VecNorm               20 1.0 9.9897e-05 1.0 4.12e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  4125
VecCopy                2 1.0 2.0981e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                27 1.0 2.6774e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               38 1.0 2.4676e-04 1.0 7.83e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  3173
VecAYPX               18 1.0 1.2612e-04 1.0 3.71e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2941
VecScatterBegin        6 1.0 3.0756e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               19 1.0 3.4723e-03 1.0 6.71e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   1  9  0  0  0  1933
MatConvert             1 1.0 1.6348e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            1 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                1 1.0 4.3261e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0  16  0  0  0  0     0
PCApply               20 1.0 8.4856e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0  31  0  0  0  0     0
KSPSetUp               1 1.0 1.2994e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.3248e-01 1.0 9.06e+06 1.0 0.0e+00 0.0e+00 0.0e+00  8  5  0  0  0  48 12  0  0  0    68
              Viewer     1              0            0     0
           Index Set    34             26       346192     0
             Section    21              3         1992     0
              Vector    26             32      1161512     0
              Matrix    10              0            0     0
      Preconditioner     4              4         4384     0
       Krylov Solver     4              4         4784     0
                 Tao     2              2         3920     0
           Index Set     8              8         6208     0
              Vector    11              2       167888     0
           Index Set     4              4         3104     0
              Vector     8              2       167888     0
Average time to get PetscTime(): 9.53674e-08
-A_ksp_rtol 1e-7
-A_ksp_type cg
-A_pc_hypre_type boomeramg
-A_pc_type hypre
-D_ksp_rtol 1e-7
-D_ksp_type cg
-D_pc_hypre_type boomeramg
-D_pc_type hypre
-log_summary
