[petsc-users] pcfieldsplit for a composite dm with multiple subfields
Jed Brown jed at jedbrown.org
Wed Sep 9 11:19:40 CDT 2015
Gideon Simpson <gideon.simpson at gmail.com> writes:
> Checking the Jacobian, this is a pretty standard output:
>       Testing hand-coded Jacobian, if the ratio is O(1.e-8), the hand-coded Jacobian is probably correct.
>     Finite difference Jacobian
>     Hand-coded Jacobian
>     Hand-coded minus finite difference Jacobian
>     6.08281e-10 = ||J - Jfd||//J|| 0.000151055  = ||J - Jfd||
> Things look favorable in terms of relative difference, but the absolute difference is a bit more suspect.
It likely just means you have big matrix entries (perhaps due to poor nondimensionalization/scaling).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150909/73b67804/attachment.pgp>
