[petsc-users] pcfieldsplit for a composite dm with multiple subfields
Gideon Simpson
gideon.simpson at gmail.com
Wed Sep 9 12:08:42 CDT 2015
The coming back to the original problem, I’m still unsure of how to diagnose the problem.
I am not sure if the listserv supports image attachments, but I dumped the snes_check_jacobian_view to disk and inspected the matrices with the spy command. I find that no entry in the saved matrix has absolute value larger than 10^{-2}. There are some that have absolute value larger than 10^{-3}, but the actual values of the entries at those indices are on the order of 100 or 1000, meaning that they are small in a relative sense.
-gideon
> On Sep 9, 2015, at 12:19 PM, Jed Brown <jed at jedbrown.org> wrote:
> Gideon Simpson <gideon.simpson at gmail.com> writes:
>> Checking the Jacobian, this is a pretty standard output:
>> Testing hand-coded Jacobian, if the ratio is O(1.e-8), the hand-coded Jacobian is probably correct.
>> Finite difference Jacobian
>> Hand-coded Jacobian
>> Hand-coded minus finite difference Jacobian
>> 6.08281e-10 = ||J - Jfd||//J|| 0.000151055 = ||J - Jfd||
>> Things look favorable in terms of relative difference, but the absolute difference is a bit more suspect.
> It likely just means you have big matrix entries (perhaps due to poor nondimensionalization/scaling).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150909/22529cd3/attachment.html>
