[petsc-users] pcfieldsplit for a composite dm with multiple subfields
Gideon Simpson
gideon.simpson at gmail.com
Wed Sep 9 11:14:55 CDT 2015
Checking the Jacobian, this is a pretty standard output:
Testing hand-coded Jacobian, if the ratio is O(1.e-8), the hand-coded Jacobian is probably correct.
Finite difference Jacobian
Hand-coded Jacobian
Hand-coded minus finite difference Jacobian
6.08281e-10 = ||J - Jfd||//J|| 0.000151055 = ||J - Jfd||
Things look favorable in terms of relative difference, but the absolute difference is a bit more suspect.
-gideon
> On Sep 8, 2015, at 11:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Sep 8, 2015, at 10:28 PM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
>> I should clarify, in that run, I ran with the analytic jacobian, but I did not use -snes_mf_operator. If I use that flag, the performance is a bit different. In particular, the true residual norms are not as good. How should I interpret that?
> The "analytic Jacobians" are wrong. Of course, that is easy to say, the hard part is figuring out exactly what entries are wrong.
> You can try the following options. They are experimental so may be flaky run with the options below (but not -snes_fd or -snes_mf_operators)
> -snes_check_jacobian
> -snes_check_jacobian_view
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150909/9b59919c/attachment-0001.html>
