[petsc-users] Modified Taylor-Hood elements with piece-wise constant pressure for Stokes equation
Justin Chang jychang48 at gmail.com
Sat May 30 22:21:01 CDT 2015
I am referring to P2 / (P1 + P0) elements, I think this is the correct way
of expressing it. Some call it modified Taylor Hood, others call it
something else, but it's not Crouzeix-Raviart elements.
On Sat, May 30, 2015 at 8:28 PM, Jed Brown <jed at jedbrown.org> wrote:
> Justin Chang <jychang48 at gmail.com> writes:
> > Hello everyone,
> > In SNES ex62, it seems to solve the Stokes equation using TH elements
> > (i.e., using P2-P1 elements). However, this formulation is not locally
> > conservative, and as a result many people use the P2-P1/P0 elements where
> > the pressure space is enriched with a piece-wise constant to ensure mass
> > conservation at the element level.
> 1. P2-P1disc is not stable.
> 2. P1disc is not "P1 enriched with piecewise constant", and the latter
> does not make sense.
> 3. You're probably thinking of the Crouzeix-Raviart element, which has
> P1disc pressure and P2 enriched with a cubic bubble for velocity.  That
> element is stable and locally conservative.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150530/fc06e6df/attachment.html>
