[petsc-users] Modified Taylor-Hood elements with piece-wise constant pressure for Stokes equation
Jed Brown
jed at jedbrown.org
Sat May 30 20:28:04 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> Hello everyone,
> In SNES ex62, it seems to solve the Stokes equation using TH elements
> (i.e., using P2-P1 elements). However, this formulation is not locally
> conservative, and as a result many people use the P2-P1/P0 elements where
> the pressure space is enriched with a piece-wise constant to ensure mass
> conservation at the element level.
1. P2-P1disc is not stable.
2. P1disc is not "P1 enriched with piecewise constant", and the latter
does not make sense.
3. You're probably thinking of the Crouzeix-Raviart element, which has
P1disc pressure and P2 enriched with a cubic bubble for velocity. That
element is stable and locally conservative.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150531/293c8e23/attachment.pgp>
