[petsc-users] Modified Taylor-Hood elements with piece-wise constant pressure for Stokes equation
Matthew Knepley
knepley at gmail.com
Sat May 30 10:08:08 CDT 2015
On Sat, May 30, 2015 at 2:37 AM, Justin Chang <jychang48 at gmail.com> wrote:
> Hello everyone,
> In SNES ex62, it seems to solve the Stokes equation using TH elements
> (i.e., using P2-P1 elements). However, this formulation is not locally
> conservative, and as a result many people use the P2-P1/P0 elements where
> the pressure space is enriched with a piece-wise constant to ensure mass
> conservation at the element level.
> Is such an element combination possible with the current implementation
> within DMPlex?
I have implemented P1_disc:
https://bitbucket.org/petsc/petsc/src/779682a0c231963f14b692ce9dcbb6520a47bf75/config/builder.py?at=master#cl-497
I believe its working correctly based on my tests for function
interpolation, but I have not tried anything hard with it.
Matt
> Thanks,
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150530/230a44db/attachment.html>
