[petsc-users] petsc-3.5.4.tar.gz now available
Satish Balay
balay at mcs.anl.gov
Tue May 26 11:46:28 CDT 2015
Dear PETSc users,
The patch release petsc-3.5.4 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
* Mat: Fix issue where the nonzerostate of Mat_MPIAIJ did not
monotonically increase when matrix entries are zeroed in B.
* Mat: bugfix for MatPtAPSymbolic_MPIAIJ_MPIAIJ()
* DMDA: DMDAVTKWriteAll_VTS - Fix handling of higher-dimension
coordinates
* MatNestGetISs: use custom fortranstub to handle PETSC_NULL_OBJECT
* Sys: fix PetscSubcommSetTypeGeneral wrt zero-ing the subsizes array
* PetscEnumFind: Fix wrong counting of entries in list
* configure: fix failure with --with-batch=1
* MatLoad_SeqDense() always allocated new space for the data even if
the user already provided it
* Added PetscBagRegister64bitInt()
* Removed direct use of HDF5_NATIVE_DOUBLE to support single
precision as well
* DMShell: destroy local to local scatter
* Fix for ISGlobalToLocalMappingApply() for when it has a block size > 1
* bugfix for MatGetRowIJ_SeqSBAIJ()
* PetscDrawLGDraw: draw and flush only in process zero
* PetscDrawSetType: Check the draw type is registered before destroying
* TS: Use %g to draw time in TSMonitorDrawSolution()
* PCMG must set initial guess nonzero for down (pre) smoother when
using full or Kaskade multigrid because otherwise it zeros out the
interpolated solution from the coarser level
* Ensure the DMDA PetscViewerBinary writer using MPI-IO functionality
respects the skip header flag when wither writing or reading files.
* Added checks to enable loading of a vector which was written
without the binary header.
Satish
