[petsc-users] Reg :PETSc Build error with mpi option
Manish Kumar K Manishkumar.K at LntTechservices.com
Tue May 26 06:42:04 CDT 2015
Hi PETSc Team,
                  Greetings of the day!
I am facing error while building building PETSc using mpich option
Please let me know where am I going wrong .
20063086 at BLRMIESPC-745 /package/petsc-3.5.3
$ ./configure --with-cc=gcc --with-cxx=g++ --download-mpich="D:/Software/cygwin/package/extpack/mpich-3.1.4" --download-fblaslapack="D:/Software/cygwin/package/                                            extpack/fblaslapack.tar.gz" --with-batch
             Configuring PETSc to compile on your system
      Running configure on MPICH; this may take several minutes
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Error running configure on MPICH.
   On Microsoft Windows systems, please obtain and install the binary distribution from
     http://www.mcs.anl.gov/mpi/mpich/mpich-nt
   then rerun configure.
   If you choose to install MPICH to a location other than the default, use
     --with-mpi-dir=<directory>
   to specify the location of the installation when you rerun configure.
The following command also gives me same error
$ ./configure --with-cc=gcc --with-cxx=g++ --with-mpich=/cygdrive/D/Software/cygwin/package/extpack/mpich-3.1.4.tar.gz  --with-fblaslapack=/cygdrive/D/Software/cygwin/package/                                            extpack/fblaslapack.tar.gz --with-batch
Help me out rectifying my build issue.
Thanks & Regards
Manish K
L&T Technology Services Ltd
www.LntTechservices.com<http://www.lnttechservices.com/>
This Email may contain confidential or privileged information for the intended recipient (s). If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150526/7fa4c5fb/attachment-0001.html>
