[petsc-users] Reg :PETSc Build error with mpi option
Dave May dave.mayhem23 at gmail.com
Tue May 26 06:58:14 CDT 2015
You should send the entire configure.log file to petsc-maint at mcs.anl.gov so
people can help you.
On 26 May 2015 at 13:42, Manish Kumar K <Manishkumar.K at lnttechservices.com>
wrote:
>  Hi PETSc Team,
>                   Greetings of the day!
> I am facing error while building building PETSc using mpich option
> Please let me know where am I going wrong .
> 20063086 at BLRMIESPC-745 /package/petsc-3.5.3
> $ ./configure --with-cc=gcc --with-cxx=g++
> --download-mpich="D:/Software/cygwin/package/extpack/mpich-3.1.4"
> --download-fblaslapack="D:/Software/cygwin/package/
> extpack/fblaslapack.tar.gz" --with-batch
>              Configuring PETSc to compile on your system
>       Running configure on MPICH; this may take several
> minutes
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Error running configure on MPICH.
>    On Microsoft Windows systems, please obtain and install the binary
> distribution from
>      http://www.mcs.anl.gov/mpi/mpich/mpich-nt
>    then rerun configure.
>    If you choose to install MPICH to a location other than the default, use
>      --with-mpi-dir=<directory>
>    to specify the location of the installation when you rerun configure.
> The following command also gives me same error
> --with-mpich=/cygdrive/D/Software/cygwin/package/extpack/mpich-3.1.4.tar.gz
>  --with-fblaslapack=/cygdrive/D/Software/cygwin/package/
> extpack/fblaslapack.tar.gz --with-batch
> Help me out rectifying my build issue.
> Thanks & Regards
> Manish K
> *L&T Technology Services Ltd*
> www.LntTechservices.com <http://www.lnttechservices.com/>
> This Email may contain confidential or privileged information for the
> intended recipient (s). If you are not the intended recipient, please do
> not use or disseminate the information, notify the sender and delete it
> from your system.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150526/0177575c/attachment.html>
