[petsc-users] MUMPS issue
    venkatesh g
    venkateshgk.j at gmail.com
    Tue May 26 01:46:11 CDT 2015
Thanks. I now have a better matrix B in my eigenproblem than last time. Now
I included MUMPS. I get this error when I give large matrices to solve:
'Error reported by MUMPS in numerical factorization phase: INFO(1)=-1,
INFO(2)=0'
I checked the manual, there is only one instance of INFO(2)=0 and I am not
able to get it.
Can someone help.
cheers,
Venkatesh
On Mon, May 25, 2015 at 6:56 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> Once again, you need a parallel linear solver.
> Read FAQ #6 and the corresponding section on the users manual.
> http://slepc.upv.es/documentation/faq.htm
> Jose
> El 25/05/2015, a las 15:18, venkatesh g escribió:
> > Hi,
> > I am solving the generalized eigen problem Ax=lambda Bx given in EX7 in
> Slepc manual.
> > Now I have restructured my matrix and I get reasonable answers.
> > However, when I submit the problem in multiple cores, it is accessing a
> large amount of memory than a serial job.
> > 1 Serial job  - Amount of memory used = 18 GB
> > Parallel job in 240 cores - Amount of memory used = 456 GB
> > I have attached the performance log for the run.
> > I think it is loading the full matrix in each core for a parallel job,
> but I am not sure how to resolve or whether I am correct..
> > Kindly help.
> > cheers,
> > Venkatesh
> > <performance_log.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150526/f2df5eeb/attachment.html>
